8100 comp cam, "machining heads"
Old Jul 22, 2008 | 10:03 AM
Kerr's Avatar
Default 8100 comp cam, "machining heads"
So i have been searcing the forums here and i foudn that few of the members ran a comp cam XR270-HR. specks here. http://www.compcams.com/Cam_Specs/Ca...csid=1078&sb=2
In the post non of them mention doing anything with the heads, but on the instulation notes it says Requires machining on cylinder heads.
So what does that really mean?
Old Jul 22, 2008 | 03:40 PM
Zick's Avatar
Personally I would call Comp Cams and talk to somebody because I don't know why you would need to machine the heads.
Old Jul 22, 2008 | 03:43 PM
InchUp's Avatar
I second the idea to call up CompCams and ask. In the mean time, send PM's to the guys who say they have installed the camshaft and ask what all is necessary to swap the camshaft in.
Old Jul 22, 2008 | 06:50 PM
1Bear's Avatar
Looking at the chart, it apears that the optional valve seals require the guides to be machined.
Old Jul 22, 2008 | 08:01 PM
Kerr's Avatar
if thats the case, that will change the cost in hurry. From what ive read the 8.1 heads are junk and only ryler makes a set... thats about $3K!
Old Jul 22, 2008 | 09:34 PM
hirdlej's Avatar
Machining is required on the spring pockets for larger diameter springs and retainers.
Old Jul 27, 2008 | 02:08 PM
TieRod's Avatar
Don't bother with Comp because they just don't know. They haven't had enough experience with the heads yet. At least thats what they told me. No machining required just change the springs and retainers and your done.
low2001gmc
Jul 23, 2015 05:10 PM
Ammadien
Jul 22, 2015 08:50 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
4B11T
Jul 13, 2015 03:48 PM
