799 heads questions?
Old Apr 23, 2012 | 09:24 AM
slowswb's Avatar
Default 799 heads questions?
I have a 5.3 with 862 on it now. so i was wonder if i mill the 799 .50 thousands and use a .40 thousands head gasket if ill have and problems with ptv clearances.
Old Apr 23, 2012 | 09:36 AM
swift700's Avatar
I think you'll probably be ok. Make sure to check before bolting down though.
Old Apr 23, 2012 | 09:39 AM
slowswb's Avatar
Havnt done it yet. Just wondering any idea what the compression would be around?
Old Apr 24, 2012 | 09:09 PM
slowswb's Avatar
anyone??
Old Apr 24, 2012 | 09:52 PM
dmelvin's Avatar
I know milled .030 with the .040 gasket, you're at 9.9:1. You'll be at roughly 57.5 cc chambers with a .050 mill. Should put you at roughly 10.3:1. As far as PTV clearances... I'm not sure, the dished pistons may give you the clearance you need. Best thing to do is to take one of your old head gaskets with the new head, torque it down, and do a clay impression, measure the impression and subtract .011 from it. This will give you your clearance with the new heads and gasket.
Old Apr 25, 2012 | 07:28 AM
slowswb's Avatar
Ok thanks for the info ill do that.
USMCvet0311
Aug 1, 2015 07:45 AM
bobfig
Jul 25, 2015 04:42 PM
low2001gmc
Jul 23, 2015 05:10 PM
Ammadien
Jul 22, 2015 08:50 PM
