6.0L L92/truck intake cam ideas
Old Jan 28, 2008 | 07:20 PM
OnyxSilveradoSS's Avatar
I am worried about stalling higher and then the intake falling off @ 6000rpm. If I can get the powerband lower in the rpms I hope that the intake wont become a restriction.
Old Jan 28, 2008 | 07:40 PM
blacksheep's Avatar
I promise the intake does not fall off at 6000.
Old Jan 28, 2008 | 09:00 PM
Steve Bryant's Avatar
LS1 Tech Veteran
Originally Posted by supersub
Steve,
Are you running L92's int that combo??
No, like it says in my signature, I'm currently running cast iron heads that I ported myself.
A higher stall speed converter works fine if you are running a lighter vehicle primarily for strip use with a big cam that doesn't make any torque down low.
If you want to enhance the performance of a street driven vehicle, especially a heavier truck, go to a slightly bigger cam, a low restriction air intake, some good street headers and a great tune. A significantly larger cam (duration over 21X intake) even with a higher stall converter does not produce broad band torque and will never have the manners it needs to a a fun daily driver. There are many, many threads on this subject both here and at LS1Tech.com and probably other places too.
Steve
Old Jan 28, 2008 | 09:16 PM
supersub's Avatar
Steve
never discussed stall speeds 2800 in a 5400lb truck will stall higher anyways it is already stated in what joe's current set up,and i dont believe what works in your combination really relates to what was asked,the L92's are different and have been proven so at a lot of other's mistakes.
I have a current l92 combo and for my particular setup hitting 425-535 lb's@ 2500-5500 rpms and that seems to workin so far.Just conveying my thoughts since I do have and invested highly into the LS3/L92 heads.
Just my MHO
Old Jan 28, 2008 | 09:22 PM
supersub's Avatar
My particular LSX L92 build up the HP peaked @6200 588hp,tq started 400+ 2500 and did not fall off until 5500 hitting 532lb's
So no worries there my friend....
Old Jan 28, 2008 | 09:27 PM
05GMCL33's Avatar
Steve
Good info Steve, I agree that with a daily driven heavy truck a bigger cam is not always better. I'm looking at doing a Comp 212/218 and keeping the stock converter for my DD but I don't tow anything.
Also want to say to my fellow PT.net member from Wichita, KS.
Old Jan 28, 2008 | 09:41 PM
supersub's Avatar
I have been looking for what would be a good cam for my 5400lbs truck? I look over @ tech and alot of people keep it a secret...so I guess throw out what I should look for since this is going in a truck.
WT=5400
gears=4.10
trans=auto
T/c=2600-2800
Intake=truck L92
This is a DD so I dont need to shift much past the 6200 where the intake seems to fall off. I am AWD. I currently have the cam in my sig, 224/224 .56ish @112...but I know the cam choice is critical so I dont lose my bottom end and plan on pulling it whan I do the heads. I have posted a few things on tech and seem to get black balled. I have heard that the smaller cam work well w/L92
L92 Spec'd somewhere around this:
207/218 615/624 on a 114 thats my guess.....Very similar have been proven with great results in our heavy trucks...
ARC
57
Feb 21, 2022 10:54 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
oharajo
Jul 18, 2015 09:24 PM
fat tony157
Jul 16, 2015 12:35 PM
