6.0L Cam Recommendation.
Old Apr 2, 2006 | 01:14 PM
parish8's Avatar
single digit dreamer
since your awd(traction) and mentioned a stall i would skip the cam and go with a stall. it will cost just a little more but will kick ***. you will get more ET reduction for the $ than you will with a cam/springs/pushrods. everyone is droping the prices of their converters lately, it might be the same price as the cam swap.
Old Apr 2, 2006 | 08:49 PM
'JustDreamin''s Avatar
Hmmmm.....
Hadn't really considered a converter......Guess I'm gonna have to think about both (stall & cam) and see what my budget will allow (if any). Or maybe just leave it alone for now....I think I'm gonna be over budget anyhow just to get it running.....
Just more research to do, right?
'JustDreamin'
Old Apr 2, 2006 | 08:55 PM
parish8's Avatar
Originally Posted by JustDreamin
Hmmmm.....
'JustDreamin'
i am intrested in what it takes to get that swap done. i had a 4wd s10 blazer with a 350 in it. the oil pan was real shallow.
Old Apr 3, 2006 | 06:46 AM
I'll let you know exactly when I get it done....I'm hoping to have it together in the next 6 weeks.
6.0l & 4wd 4L80E are sitting in the garage. Bravada is waiting patiently with a 2 speed 4L60E (still has 1st and 3rd).
I'm sure the oilpan will be pretty shallow. I'm planning on building one from scratch, because it'll be easier than modifying the alum pan (I can weld steel, but don't have the hardware / skill for alum). Nice thing about the LSx series is the oilpan flange is flat, makes it alot easier than a standard SBC.
Still have a bunch of stuff to get, including a transfer case from Rockland Standard Gear. They're going to build me a NV246 without low range (basically a NV146) to run in place of the NV136 and mount up to the 80E.
'JustDreamin'
Old Apr 7, 2006 | 06:00 PM
litreddevil's Avatar
Banned
i would have to agreewith parish on this on
Old Apr 7, 2006 | 06:02 PM
Banned
'JustDreamin'
i have a friend of mine that just put a 5.7 in a 4 door s-10 blazer an did not have to my a oil pan they redone the k member man did that thing come out good
ARC
57
Feb 21, 2022 10:54 AM
2500ZL1
Jan 25, 2016 06:30 AM
FlowmasterMufflers
Aug 14, 2015 01:04 PM
Denali08
Aug 9, 2015 04:34 PM
oharajo
Jul 18, 2015 09:24 PM
