6.0 Rebuild
Old May 27, 2008 | 09:53 PM
HorsePower Hunter's Avatar
Default 6.0 Rebuild
I'm currently rebuilding my 6.0 I need a set of forged rods and pistons. Can anyone tell me the stock rod length and piston size for a standard bore. Also, I know this has been beaten to death, but any recommendations for my build. I have a stock cam and crank. I have a set of 72cc stage 3 heads, studs, cometic gaskets and will be going back with FI.
Old May 27, 2008 | 10:03 PM
chevyguy7802's Avatar
Standard bore is 4.00 and the rod length is 6.098
Old May 27, 2008 | 10:19 PM
gao8302's Avatar
Stock piston bore is 4.00
Rod length is 6.125
I went with diamond pistons and eagle rods on my build. So far im very happy with everything that i picked. Just pick your piston cc and your CR. You will have to decide what and how much boost your going to run. Im running a 9.3-1 CR. I would also go with a bigger cam while your in there along with everything else. Such as timing chain, lifters,ect. I didnt skimp on anything and im glad i didnt because i have a peace of mind now. There is alot that goes into these builds. If you have any question on what i used i will post the link to my build and parts list. But i would go with at least a zo6 cam if your going boost.
Old May 27, 2008 | 10:21 PM
gao8302's Avatar
My 370 build.
https://www.performancetrucks.net/fo...d.php?t=415161
Old May 29, 2008 | 10:52 AM
Rod length is 6.125
Thanks guys, but which length is the right one?? Also, thanks for the link gao8302. I have some comp lifters laying around that I had in a 408, but the top retainer came lose on two of them. I'm kinda scared to try them again stock lifters seem to work fine.
Old May 29, 2008 | 11:19 AM
gao8302's Avatar
Comp lifters are no good. Just get some LS7 lifters. 6.125 is the correct length. Check out Texas speed and performance for all your engine parts. They have the best prices and carry everything you need.
Old May 29, 2008 | 11:21 AM
gao8302's Avatar
You should just bore it over to a 370. Do it once and be done with it.
Old May 29, 2008 | 01:07 PM
white lightning SS's Avatar
when you bore your block I would recommend running closer to stock clearances to eliminate noise. the 4-5 thousands recommended is too much. I learned this after three motors
Old May 29, 2008 | 02:07 PM
kbracing96's Avatar
6.098 is the stock rod length, 6.125 is the common aftermarket rod length, but you have to make sure to get the right pistons for them.
03sierraslt
14
Oct 9, 2015 05:53 AM
turbo6c3
Oct 5, 2015 06:11 PM
gmcyukon
Oct 5, 2015 06:20 AM
trevorh1
Sep 27, 2015 08:47 PM
sTNT971
Sep 26, 2015 06:27 AM
