6.0 problem!!!
Old May 12, 2008 | 02:33 PM
stockgmc's Avatar
Default 6.0 problem!!!
well me and a buddy of mine were sitting at the post office the truck was running fine, a few seconds after we parked, the truck started skipping and was about to cut off, so i eased my foot onto the gas and it idled up. I looked in my rearview and white smoke everywhere. he doesn't live far away so i drove it to his house. assuming it was a fuel pressure regulator i went to get one (not driving my truck). i got back and put on the regulator and tried to start it. it tried to start then made a bad noise after this starter would not turn the motor.
to shorten the story, an injector was stuck open leaked the fuel out of the rail into the cylinder. i pulled the plugs to let the gas out and replaced the injector that was stuck. now its knocking and when it warms the blue smoke comes. what ussually is the problem when this happens? and is there any reason i couldn't stroke it?
Old May 12, 2008 | 03:09 PM
SS_bnoon_SS's Avatar
White smoke out the tailpipe usually isn't fuel related, it's usually water. To much fuel is black... oil is blue... Are you sure you didn't hydro-lock a cylinder?
Old May 12, 2008 | 04:05 PM
TexCrew's Avatar
damn..
Old May 12, 2008 | 04:20 PM
krambo's Avatar
That was the first thing I thought of. Trying to compress a liquid is....
Old May 12, 2008 | 05:21 PM
10 Second Truck Club
whatever it is, good luck fixing bro
Old May 12, 2008 | 06:09 PM
fastgmc98's Avatar
I had an s10 hydrolock on me before(nitrous backfire, blew the intake into pieces but fuel still got into the cylinders) and It had just the slightest knock till I checked the compression and 5 cylinders were 170psi and one was 10psi long story short the hydrolocking occured mainly in one cylinder and "IMPLODED" the ringland, bent the rod and tore up the cylinder. Anyways good luck fixing it.......
Old May 12, 2008 | 09:49 PM
stockgmc's Avatar
im sure it wasn't water. thats what i thought at first but when i got out of the truck i could smell raw fuel. also when i removed the plugs they were all dry except for the back cylinder on the passenger side, gas poured out.
Old May 12, 2008 | 09:54 PM
stockgmc's Avatar
i hope the cylinder walls arent hurt too bad, the truck runs fine except for knock and smoke. i havent driven it any im taking the 6.0 out and putting in a stock 5.3 (hopefully temporary until 408).
its just wierd i had the 8.1 marine injectors and ive never heard of them just sticking like this.
Old May 12, 2008 | 10:20 PM
dlt76028's Avatar
that sucks man. hope you get everything worked out
Old May 13, 2008 | 03:50 PM
chris04's Avatar
[QUOTE=stockgmc;3918781] (hopefully temporary until 408).QUOTE]
408......hmmmm....... i like the way that sounds.
Tigger Welder
Oct 1, 2015 08:41 AM
mitchellmade
Sep 27, 2015 08:27 PM
Pimpinpete
Sep 8, 2015 07:39 PM
chvy=power
Sep 8, 2015 11:06 AM
