6.0 Build Up
Old Aug 7, 2006 | 06:36 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
4.100 you dont even want to get into all of the PITAs that it causes Go 4" if you stroke it.
Old Aug 7, 2006 | 06:37 PM
1slow01Z71's Avatar
Originally Posted by thiems
You are going to make it a 408, right???
a 408 would require a 6.125" rod and a 418 will require even more expensive custom pistons to clear the extra .100" of stroke then you get to still clearance the pistons and counterwieghts and every damn thing else
Old Aug 7, 2006 | 06:38 PM
dirt track racer 81's Avatar
im seriously thinkin of getting a loan to build this up..if i go 408 which rod do i use then??
Old Aug 7, 2006 | 06:42 PM
1slow01Z71's Avatar
6.125 same rod whether 408 or 418 the 418 requires even more extra special piston measurement BS. Get a full rotating assembly its the easiest way and you know you wont have clearance issues.
Old Aug 7, 2006 | 06:45 PM
ls2's have a floating pin..do the lq9's have a floating pin?
Old Aug 7, 2006 | 06:46 PM
1slow01Z71's Avatar
yup..
Old Aug 7, 2006 | 06:50 PM
alrighty thanks alot..sorry im out a questions for now..
Old Aug 7, 2006 | 07:51 PM
Quik's Avatar
5 year bitches!
use the 317s and mill them!!! or find a set of 243s i wouldnt waste my time on them. sicne the 317s flow alot more
Old Aug 13, 2006 | 05:27 PM
Tahoe6.0's Avatar
How much do yo mill a 1 point drop and what pushrods do you do.(length) i, going with a 02 ls6 cam and 317 heads milled?
Old Sep 8, 2006 | 09:48 AM
SLED28's Avatar
FormerVendor
All you have to do is clearance the pistons just under the pin to clear for the counterweights. I've done a bunch of these, it just takes time. Who built your 4.100 motor?
