6.0 Build Up
Originally Posted by thiems
You are going to make it a 408, right???
6.125 same rod whether 408 or 418 the 418 requires even more extra special piston measurement BS. Get a full rotating assembly its the easiest way and you know you wont have clearance issues.
a 408 would require a 6.125" rod and a 418 will require even more expensive custom pistons to clear the extra .100" of stroke then you get to still clearance the pistons and counterwieghts and every damn thing else
Go 4" if you stroke it.
