6.0 bored out max?
Old Aug 7, 2007 | 04:31 PM
Quik's Avatar
5 year bitches!
Default 6.0 bored out max?
just out of curiousity. how large of a motor can a 6.0 be punched out safely? reason asking is i need to get new pistons for the 408 and was just curious to see if i had to clean up the walls at all how far can i go without buying a new crank and rods
i know slowz71 is up there in bore and has had troubles. just want ot hear ppls opinions
Old Aug 7, 2007 | 04:45 PM
nightrunner's Avatar
Mr. Obvious
i think what happened to slow is he went to 4.1" stroke and had problems with that
Old Aug 7, 2007 | 04:49 PM
Stoichiometric's Avatar
I have heard .040" over, but less is better. What is the condition of your cylinders right now?
Old Aug 7, 2007 | 04:51 PM
Quik's Avatar
5 year bitches!
they look good from up top but i havent put it on a stand yet. once its tore down then ill knwo for sure
Old Aug 7, 2007 | 05:10 PM
adam1803's Avatar
Im just curious, why does the 408 need new pistons already?
Old Aug 7, 2007 | 05:23 PM
Quik's Avatar
5 year bitches!
had an issue with valve float or spring bind not sure exactly.. but my #7 cylinder is wiped out. look in mulitmedia to see the pics
Old Aug 7, 2007 | 06:47 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
My block sonic tested just fine for a 4.04 bore. The 4.1" stroke is what caused alot of my problems with an improper piston design thanks to JE
Old Aug 7, 2007 | 06:53 PM
BlackGMC's Avatar
Resident Retard
is sleeving the bad cylinder an option for you?
Old Aug 7, 2007 | 09:21 PM
quicksilverado's Avatar
It would be cheaper to get another 6.0 block and have it bored.
Old Aug 7, 2007 | 09:32 PM
FarmerBeau's Avatar
Sexy Party Mod
If that is the case, why dont you just get a new piston, block and have it machined. It would probably still be cheaper and i know you have to have some hookups.
