5.3L build
Old Sep 18, 2008 | 02:53 PM
InchUp's Avatar
Originally Posted by jeforton
alright i'll look into that. would you know what kind of gains i could expect from a worked throttle body? lets say i get my heads worked, and get say .040(???) taken off, would i need shorter push rods er wouldn't that matter? oh, and with bolt ons, cam, and heads, would i need bigger injectors?
Throttle response is what you're after with a ported throttle body. The gains will be minimal at best as for horsepower/torque, but the additional inrush of air at the same throttle % is what you'll feel, making the motor "peppier" and quicker to follow your foot's requests for power.
Consult your machine shop for how much to mill the heads. How do you know to take .040" off? Tell your machine shop the target compression ratio, and let them go to work.
Pushrod length should be checked by a pushrod checker and determined after you come up with a measurement. You'll know how long they need to be after you mill the heads and button the long block up, heads and all.
Chances are you will not need bigger injectors. I say that lightly though, because you'll need to tune the motor once complete anyways, so let the tuner tell you the duty cycle of your stock injectors. Check first, see where you stand, then go from there.
Old Sep 18, 2008 | 03:14 PM
jeforton's Avatar
that's just a number i took out of no where. to be honest, i know nothing of doing head work.
so you'd suggest letting the shop do all the work?
Old Sep 18, 2008 | 03:35 PM
InchUp's Avatar
At least doing the machine work and helping with suggestions. There are very few things more helpful than a local shop assisting you on the way. You build maybe 1 motor in a year...if that? They build motors every day. Let the experienced do their job.
Old Sep 18, 2008 | 03:42 PM
jeforton's Avatar
ya, that's a good point. still though, there is something to be said for doing your own work.
Old Sep 18, 2008 | 03:51 PM
joshua022's Avatar
I put down 390rwhp and 366 rwtq with my 5.3 and the tsp stage 2.5 heads and a custom ground tr224 cam.
here is my build thread.
https://www.performancetrucks.net/fo...d.php?t=411133
Old Sep 18, 2008 | 04:30 PM
jeforton's Avatar
holy crap. those are some nice #'s. what are the rmp's for those #'s? how rough does it idle and at what rmp?
5.3lSilverado
25
Aug 29, 2016 12:48 AM
jrcabby
Aug 24, 2015 09:40 AM
USMCvet0311
Aug 14, 2015 10:28 PM
05GMC4.8
Aug 7, 2015 09:55 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
