5.3 TR 224 cam H/C/I
Old Jul 7, 2009 | 03:17 PM
Chevy96's Avatar
Default 5.3 TR 224 cam H/C/I
Hey guys with a TR224 cam a FAST 90mm and a set of heads( i can't figure out which heads to go with but i was thinking stage 2 patriot heads) what kinda of dyno numbers can i excepect. (thisincludes LT's and 2.5 inch exhuast with efans) out of a 5.3
Old Jul 7, 2009 | 04:34 PM
02_Orange_D1SC's Avatar
Fastest D1 Procharged Truck
for heads id look a set of AFR 205s or a set of TRICK FLOW 205s as far as power id say somewhere around 350 to 375 RWHP
Old Jul 7, 2009 | 07:18 PM
Chevy96's Avatar
really dang i was hoping for something in 4xx rwhp range, so its gonna take a power adder to do that ?
Old Jul 7, 2009 | 08:42 PM
there was a built up of a stout 5.3 over on RGV performace trucks it made 490 to the flywheel ill see if i can find it
Old Jul 7, 2009 | 09:02 PM
found this on LS1tech:
Here's what was in the engine:
5.3 block aluminum (doesn't really matter if it's iron)
4.8 flat top pistons
5.3 rods - ARP rod bolts
5.3 crank
LS2 timing chain on 5.3 sprockets
LS2 intake/injectors/fuel rail (modified by Turn Key)
90mm Turn Key throttle body
220/224 112 LSA Trick Flow cam (.575 lift)
Trick Flow 205 CNC ported heads (assembled)
Harland Sharp pedestal mount 1.7 rockers
Trick Flow 7.500 chromemoly pushrods
Correction factor was 1.046
91 octane pump gas on a Superflow 901 engine dyno. We estimate compression at around 11.5:1
Old Jul 8, 2009 | 01:27 PM
Chevy96's Avatar
now thats a pretty engine, looks like i might be mimicking this build thanks for the help
Old Jul 8, 2009 | 01:58 PM
yup it sure is a nice looking setup i must say and makes nice power also
Old Jul 8, 2009 | 04:37 PM
budhayes3's Avatar
PT's Slowest Truck
Keeping intake duration around 220ish seems to work real well in the 5.3's, just look at what bluecajun has done with a TR220
Old Jul 8, 2009 | 06:54 PM
closet red neck's Avatar
I'm selling my set-up soon and I put down 409rwhp and 390ish rwlb-ft of torque running through a transfer case.
Jamse
Old Jul 9, 2009 | 02:56 PM
Chevy96's Avatar
if so let me know when you are, is it the whole motor or just the parts ? and whats the drivetrain loss through a transfer case ?
