5.3 questions and help
Old Jul 26, 2007 | 07:56 PM
kbrock's Avatar
Default 5.3 questions and help
I decided to post this in the truck forum because the ls1 tech guys only think you can make good power with a stroker or just sell the 5.3 and buy a 6.0. Okay what I have is a 65 chevy II that I am putting carbed 5.3 with a th350. This will be a street strip car. I am looking for 10.99 quarter passes. The car is going to way around 3000lbs so I know i need around 450hp to the wheels. I am thinking that I can do it with a cam, head work(porting),get the compression around 10 to 1, and a little shot of nitrous. I want to run the stock block except for the cam. I don't have power brakes, ac, or power steering. All I will be running is the water pump and alternater. I would like your thought on a cam and what size to run. Also what kind of power should I be putting down without nitrous.
Old Jul 26, 2007 | 08:15 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
The most reported from a 5.3 on this forum NA is ~340. What are your plans for torque converter?
Old Jul 26, 2007 | 08:22 PM
kbrock's Avatar
I don't know about the torque convertor until I decide what cam but I was thinking about a 3000 to a 3200 stall so it will still be streetable. I was thinking that some of you guy would be in the 370-390 NA range as far as horsepower. How much do some of you guys truck weigh that are running low 12's.
Old Jul 26, 2007 | 09:12 PM
trever1t's Avatar
See the Dyno truck list....
https://www.performancetrucks.net/fo...d.php?t=348390
and the drag racing list..
http://www.deweygibson.com/PT.NET/ftlquarter-dew.htm
Most ecsb's weigh 5000-5300 and rcsb's ~ 4500-4800lbs
As for cam, just think slightly smaller than you would for the 5.7
Old Jul 27, 2007 | 05:04 AM
Spoolin's Avatar
GFYS and STFU
Originally Posted by kbrock
...I was thinking that some of you guy would be in the 370-390 NA range as far as horsepower.
Full bolt on 6L's are seeing those numbers but nobody to my knowledge has seen 400rwhp yet, let alone with a 5.3L. If your looking for longevity (which you seem to be looking for) I don't think you can find it with pushing the 5.3 to the limits. Upping the compression ratio will help but since your using stock rotating assembly your gonna run into fatigue problems. But with nitrous anything is possible. Now if you were to go FI you'll break into single digits with that stock 5.3L and a 3000 lbs car.
Old Jul 27, 2007 | 05:24 AM
kbrock's Avatar
5.3 crate motor I would think that these hp figures are at the motor but there is not really alot done to this motor. Do you think these numbers are right?
Old Jul 27, 2007 | 12:19 PM
NegraRCSB2X4auto's Avatar
kind of high
Old Jul 27, 2007 | 07:52 PM
kbrock's Avatar
If those numbers were right I was thinking that my th350 would probably only eat around 50hp so I would be around 370hp. What do you guys think?
Old Jul 27, 2007 | 09:34 PM
trever1t's Avatar
Gen III 5.3 Vortec Cast Iron Block Assembly
· Aluminum Vortec Heads 1.850 Intake 1.550 Exhaust
· Custom Wiring Harness & PCM (6500 Rev Limit)
· 75mm Truck Intake Manifold
· 28lbs/Hour Injectors
· 540 Lift Hydraulic Roller Cam
· Low Oil Pressure Shut Down
· Truck Water Pump
· 85 Amp Alternator
· Flywheel and Starter
· Power Steering Pump
· Fuel Pump
· Serpentine Belt Drive
· Truck Exhaust Manifolds & Motor Mounts
· Installation Instructions
· 1 Hour Engine Dyno Test
I don't think this engine will make 300hp to the rear wheels, but I am far from an expert.
I would look at http://www.sdparts.com/product/19165...2HPEngine.aspx for a more realistic picture. The 5.3L HO rules
ferrellrooster
Mar 6, 2025 03:22 PM
USMCvet0311
Aug 1, 2015 07:45 AM
vmaxpro
Jul 27, 2015 10:45 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
grantpo
Jul 15, 2015 12:21 PM
