5.3 into 5.7
Old Jan 25, 2008 | 05:01 PM
jhe2003's Avatar
Question 5.3 into 5.7
Looks like i'll be getting a 5.3 from another member here and I've seen some guys around here throw around the idea of making a 5.3 into a 5.7.
What will it take? Can I use ls1 internals? Going from 5.3 to 5.7 will I have to bore it out and leave the stroke alone?
I was thinking buying the crank, connecting rods and pistons "off the shelf" from an ls1 and installing them. Will this work or will I run into problems? Also what will be the effect of using the 5.3 heads with this set up?
Engine will be a DD with a mild cam and long tubes, not to crazy
Any input appreciated
Old Jan 25, 2008 | 05:04 PM
joshua022's Avatar
All you need to do is have it bored. everything off of a LS1 will work, and the 5.3 heads will bump up compression a little bit, but they don't flow as well because of the little valves.
Old Jan 25, 2008 | 05:17 PM
My brother has this setup in his 67 swb with a patriot 226 cam and it runs damn good.
Old Jan 25, 2008 | 07:31 PM
TarheelZ's Avatar
You're describing exactly what I want to do! I'll be getting my 4L60e rebuilt with 'beefier' components pretty soon; then it's time to start planning to build an iron-block 5.7L
Old Jan 26, 2008 | 01:09 AM
PappyDan's Avatar
Tribe Shaman
Well, if you going to buy crank, rods, and pistons then go for a 383.
if you want to save some cash then all you need is a set of LS1 pistons and
Have the block bored for a 5.7.
now you can add the 02 LS6 camshaft and the 243 heads for an iron block 5.7
That is rated for 405hp @ the crank.
Old Jan 26, 2008 | 09:54 PM
jhe2003's Avatar
I like your idea!! I think I'll go just with the pistons, bore it out, get the camshaft and heads and this should be enough for what my needs are. I doubt it will get sprayed or blown Oh yeah I forgot, FLT will be getting a call in a couple of months too
Old Jan 29, 2008 | 02:04 AM
mike06tork's Avatar
whats the biggest bore on a iron 5.3 can be made could it be bored to fit some 4.000 pistons with stock crank im try'n to make this happen also
Old Jan 29, 2008 | 08:00 AM
xlr82sxs's Avatar
max bore on a 5.3, 3.90 with a 3.62 stroke.
Old Feb 4, 2008 | 02:42 AM
mike06tork's Avatar
are the stock 5.3 rods are the same as the ls1 rods?
Old Feb 4, 2008 | 02:43 AM
mike06tork's Avatar
and can i bore the 5.3 iron to 3.905 bore and be safe .?
