5.3 heads
Old Nov 25, 2007 | 01:01 PM
iamkeniff's Avatar
Default 5.3 heads
i am building my truck one part at a time. don't get me wrong, money is easy to come by if i want to work a lot, but i love being home with my family so i stopped working so many hours.
i'm trying to read up on milled/p&p/valve job on my 5.3 heads.
or should i pick up some 6.0 heads bare or assembled and have the same thing done but with smaller valves i think is what i'll need.
i don't want to spend 1500-2500 on JUST Heads.
i am going to stay with my stock intake, because i don't see it to be a wise desicion to buy a 90MM FAST intake and T.B.
i don't want to do an LS1 swap or anything wild like that.
just a N/A 5.3
current mods are:
P&P T.B
Pacesetter L/T
ORY
Descreened MAF
C.A.I.
I have a VIG3200 stall and a 24k Transmission Cooler
M/T ET Streets 26x10.5x16
Custom Tune from dc_Justin (i think that is his s/n on here)
i am going with a FLT Level 4 Transmission
my next mods that i am getting are
4:10:1 with a Detroit TrueTrac
Rebuilt Rearend
TA Performance Products Rear End Cover from Thunderracing.com
Old Nov 25, 2007 | 09:06 PM
Truckshop's Avatar
i just bolted on a set of milled 243 heads with a tr220-112 cam. love the way it sounds and it runs great.if you are looking for a set of 5.3 heads to play with let me know. unless you have a spare set already. i am also not far from you.
Old Nov 25, 2007 | 10:29 PM
iamkeniff's Avatar
hunder Racing Custom Camshaft
"Reverse Split" - 230/224 .575/.563 111 LSA 2200-6800 RPM Power Band. Excellent mid-range & high RPM power. Automatic cars require computer tuning and it is recommend for optimum results on manual transmission cars . Due to the fast ramp rate of this camshaft, the use of 1.8 rockers is not recommended.
im thinking of running this on my 5.3 heads after i get them back from WCCH in cali and have them milled down.
what do yall think, how will it idle?
i'll be putting 8.1 marine injectors too
TruckShop i PMED you about the stockers let me know the mileage and how much you are looking to get for them.
thanks
Old Nov 26, 2007 | 09:35 AM
Truckshop's Avatar
i was thinking about $150 for the heads but i haven't looked to see what they are going for. the tr220-112 in my truck lopes pretty good so the one you are looking at should too.
Old Nov 26, 2007 | 09:42 AM
Phantom's Avatar
11 Second Club
thats a big ol' cam keniff
Old Nov 26, 2007 | 09:53 PM
iamkeniff's Avatar
yeah, but i decided that i'm going with a 6.0 now.
i'm on the HUNT for one, and if they are under 450 miles away from me, i'll drive and pick it up
Old Nov 26, 2007 | 10:28 PM
Tootall's Avatar
V8 on here has an even bigger cam than that in his 5.3 also
Old Nov 26, 2007 | 10:30 PM
RandomHero's Avatar
with a 3800 converter though.
Old Nov 26, 2007 | 10:34 PM
TouchOfEvil04's Avatar
He's not goin 5.3 anymore he's goin 6.0l and he has a single disc vig 3200 in a ecsb so that thing is gonna flash like 3400-3600 easy so i think he will be just fine. Also goin to be running 4.30 gears.He will be fine.
JordanH
Aug 8, 2015 07:59 PM
elpyro89
Jul 28, 2015 05:51 PM
steves86ta
Jul 28, 2015 10:21 AM
vmaxpro
Jul 27, 2015 10:45 PM
06 4.8
Jul 15, 2015 07:17 PM
