engine block
Old Nov 23, 2007 | 07:02 PM
xdanny510x's Avatar
Default engine block
how does this block sound instead of my old dead 5.3
New GM 6.0L Cast-Iron Block
Item#:
28-12551366
Brand New GM 6.0L Cast-Iron Block, 4.0" Standard Bore
Bare (No Pistons, Rods, or Crankshaft)
Perfect For Building Your 400+cid Stroker!!
or this one
New GM 5.7L Aluminum LS1/LS6 Block
Item#:
28-LS1Al
Price/ea.
GM 5.7L Aluminum LS1/LS6 Block, 3.898" Standard Bore, Bare
Old Nov 23, 2007 | 07:17 PM
rivierakid55's Avatar
you gonna reuse your existing heads?
Old Nov 23, 2007 | 07:19 PM
xdanny510x's Avatar
yup on planning too.. to use as much as the old parts as i can..maybe some after market pistones
Old Nov 23, 2007 | 08:28 PM
03sierraslt's Avatar
You should keep your eye out for someone selling a set of 317 heads. They will flow better then the 5.3 heads, unless you want to run the 5.3 heads for high CR.
Old Nov 23, 2007 | 08:56 PM
xdanny510x's Avatar
yea tryna get a lil bump in compression ...which ones would be better if i port and polish them.. my 706's or the 317's
Old Nov 24, 2007 | 01:34 AM
Jessica's Avatar
Restricted User
The 317 heads are nice but a 243 is better still..... Why not go with a LS2 block? Other than the covers and sensors can be a pain in the *** it's lighter. Hell SDPC has the L92 motor for $5300 or something retardedly low.
A LS1 block with 243 heads would be a nice upgrade. Lighter weight and more power.
Old Nov 24, 2007 | 07:10 PM
xdanny510x's Avatar
whast the difference between the ls2 block and the standard 6.0 block right/? just that one is alumin. and the other cast iron right?
Old Nov 24, 2007 | 07:53 PM
jakebdb56's Avatar
one is a genIII and the other is a genIV
different ecm, different sensors (cam, crank, etc.), and a few other changes.
Old Nov 24, 2007 | 08:46 PM
nonecktribe's Avatar
if you got the money go with what ever gives the best power for the buck
Old Nov 24, 2007 | 09:03 PM
xdanny510x's Avatar
and which one would that be???? would my cam work with the ls2 if i go that route? as well as my bolt ons?
