5.3 head work and cam
Old May 16, 2010 | 01:02 PM
  #21
Y@ BoY p@Ul's Avatar
So more less wut yaw are sayin is run the pac 1218's rather than the ls6 springs? Not to many ppl around here where i live do this kinda stuff so thats why im having to ask yaw wuts best to use.
Old May 16, 2010 | 06:11 PM
  #22
budhayes3's Avatar
PT's Slowest Truck
Depends on which cam you choose...if going with the Comp 212/218, low or high lift, the LS6 springs will be fine, but for the TR220 that was recommended, I'd run the 1218's if it were me. You'd probably be fine with LS6 springs, but should definitely be fine with 1218's, which are comparable (read: same thing minus the Comp breakage problems) to the Comp 918's that Thunder Racing recommends with that cam.
Old May 17, 2010 | 12:36 AM
  #23
Z'06's Avatar
I think you meant ramp rate...the TR cams need more seat pressure than the LS6 springs have...can't remember the open seat pressures, but the LS6 springs have a closed seat pressure of 90# as opposed to 130# for the PAC 1218's.
Doh! You are correct that that's what I meant.
The PAC 1218's and Comp 918's actually have the same exact specs, except that the Comp's are known to break and the PAC's seem to have a great track record so far. It's my understanding that PAC used to make the springs for Comp, but Comp changed suppliers...probably getting a better deal on the junk their selling now.
Yep. Best to stick with the original source!
Old May 17, 2010 | 01:30 AM
  #24
Bumpers's Avatar
Tr220 and pac1218s in my rig and it works great..m a 3200 converter works well with the 220 also
Old May 20, 2010 | 03:27 PM
  #25
I really dont want to get into changin converters and all that. But i know ill have to do some stuff to my trans just be safe but thats fine.
Silveradorst07
Dec 31, 2015 12:04 AM
steves86ta
Jul 28, 2015 10:21 AM
06 4.8
Jul 15, 2015 07:17 PM
4B11T
Jul 13, 2015 03:48 PM
07NBSChevy
20
Jul 8, 2015 07:27 PM
