5.3 castings?
Old Oct 15, 2008 | 10:42 PM
lsx10's Avatar
Default 5.3 castings?
whats the difference between the different casting numbers of the 5.3/4.8 heads?
Old Oct 15, 2008 | 10:53 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
I think they're all pretty much the same until you get to the later 05+ 799 castings. The 799's are interchangeable with the 243's. Larger valve, 64cc combustion chambers, improved flow.
Old Oct 16, 2008 | 11:59 AM
lsx10's Avatar
alright, I was talking about the 862 heads and 706 heads, I tried reading around but just wanted to be sure.
Old Oct 17, 2008 | 12:45 AM
1FastBrick's Avatar
Custm2500's Rude Friend
If I am not mistaken the only difference is in the way they are cast. 706 uses a Semi Permanent Mold process and the 862 use a sand cast process. Its said that the SPM process is a little more precise. You can find a little more info in Will handzel's book "How to build High-Performance Chevy Ls1/Ls6 V-8s" Alot of detail and Backround on the Gen 3 Platform.
BigE
Feb 21, 2018 11:44 AM
Go5.3tt06
25
Sep 4, 2016 10:25 AM
pewter00
Sep 14, 2015 09:17 PM
11MPG
Sep 10, 2015 08:34 PM
11MPG
Sep 8, 2015 04:52 AM
