5.3 to a 383?
Old Sep 27, 2007 | 05:49 PM
  #31
whitesilvy04's Avatar
Originally Posted by sleek silverado
I came up with $5000 part list to build the 383. This is using some of the best parts avaliable. Then, there is the cost of prepping the block, balancing and assembly. By the time it is over I would have a $8000 motor with the h/c I already have.
^ thats alot of money to build considering you can buy a all forged long block 408 from texas-speed and still save over $1,000
Old Sep 28, 2007 | 11:30 AM
  #32
Mark Johnson's Avatar
Good thread- say, can I get away with some stock pitons out of a Camaro after I punch out the block to the appropriate bore? I'm gonna 5 axis CNC my 5.3 heads and away I go..................
Old Sep 28, 2007 | 07:19 PM
  #33
Onetogofast's Avatar
Go big or go home is always my vote, like above the second time fix sucks ***.
Old Oct 22, 2007 | 11:54 AM
  #34
v8sten's Avatar
9 Second Club
Default stroker short block
i agree with whitesilvy04, why spend that much on a short block that may give you problems later. i am all for building your own sh*t, i built my 383 in my s10. but sometimes you have to look at the cost and effort of building something. if its cheaper to just buy a 408 short block with great parts in it , why not. hell on the main page of texas-speed there is a 454 c.i. lsx for $5845.00. it comes with an eagle crank, scat h-beam rods, and diamond pistons, id go with that.
heres a link:
http://texas-speed.com/shop/item.asp?itemid=709
Old Oct 22, 2007 | 01:37 PM
  #35
TurboGibbs's Avatar
Originally Posted by IMD
if you're talking stroker stuff, youre going to have to buy pistons, rods, and a crank no matter what block you put them in. in my opinion, theres no point spending the money to bore your 5.3, then buy the rotating assembly to make a 383. if you're going to buy all this stuff, why not put it all into a 6.0 block and have a 402 or 408, for exactly the same money. theres an easy 50 ft.lbs and 50 hp just in the displacement difference. theres really no good reason to make a 383 out of a 5.3....at least not cost wise. theres no cheap or half assed way to do it. either spend the money on a turbo kit, or on a 6.0 stroker, and stop fu*&ing around.
Well with that mentality then anyone wanting a stroker should throw away their 4.8,5.3,5.7,6.0,6.2,7.0 blocks and build a LSX block.
Old Oct 22, 2007 | 01:41 PM
  #36
TurboGibbs's Avatar
I rescently build a 383 stroker out of a 5.3 block for Curtd. He has run 9lbs boost on it so far and no problems yet. It actually ended up with 3.9115" bore after proper piston clearencing.
Pontiac Derek
Sep 19, 2015 01:49 PM
Pontiac Derek
Sep 18, 2015 09:02 AM
pewter00
Sep 14, 2015 09:17 PM
11MPG
Sep 10, 2015 08:34 PM
11MPG
Sep 8, 2015 04:52 AM
