454 to 427 help
Old Oct 12, 2010 | 11:00 AM
  #21
viciousknid's Avatar
Where's the Beef?
One discrepency I noticed in your calculations is the deck height. I'll have to check it myself when I get all of this mustang stuff done but online I only find 9.800 deck heigh on a 454 apposed to the. 9.780 u mentioned.
If correct wouldn't that make the pin height 1.782"?
Old Oct 12, 2010 | 12:07 PM
  #22
1Bear's Avatar
It’s not really a discrepancy, your right in that the stock deck height is advertised as being 9.800” and a tall deck block would have been 10.200”, but what I’m asking you do is look into is decking the block .020” to get the compression where you want it with out of the box type pistons. It probably needs close to that to square the block back up anyway and to zero deck it to the final piston height. This is where the machine shop comes in. What your going to run into (as you’ve already figured out) is finding few box stock parts that fit the dimensions your looking for and will need to make concessions. Another issue with just picking stock type components on a traditional big or small-block and hitting a given target compression ratio is, unlike today where it is common for the piston to protrude past the deck height, the pistons were typically located somewhere around .020” down in the hole.
If you didn’t deck the block and were trying to attempt a 0 deck height, yes indeed you would be looking for a piston with around a theoretical 1.785” pin height.
Old Oct 12, 2010 | 12:32 PM
  #23
Where's the Beef?
I see. Thanks again. Just wanted to make sure I understood what needed to happen. I get what you mean. I'll let him know.
Old Oct 12, 2010 | 01:39 PM
  #24
1Bear's Avatar
Another reason you’re finding conflicting information everywhere you turn, is GM played with the piston pin height for the various engine combinations.
For example:
Low Performance*********Pin Ht.
396-402-427*************1.770”
454********************1.640”
High Performance*********Pin Ht.
396-427*****************1.760”
(1968 Only)
396-402-427**************1.765”
454-502*****************1.645”
Old Oct 14, 2010 | 04:33 PM
  #25
STXTahoe's Avatar
Registered User
1Bear, I have been building big blocks for years and I have yet to hear someone explain it correctly. awesome brother, just awesome.!!!
dragpac
Dec 8, 2015 05:48 AM
racedad70
Sep 16, 2015 01:51 PM
Raylar Engineering
Aug 26, 2015 10:36 PM
Alco
Jul 25, 2015 01:47 PM
