408ci
Old Aug 3, 2008 | 09:28 PM
redchevytruck's Avatar
Default 408ci
any one no much about them....
trying to figer out a good cam for mine...
was thinking about a ms4... ? or maybe bigger...
most all cam are set for a 349ci motor...
how can i figer out the diff. for my 408ci motor
Old Aug 3, 2008 | 09:35 PM
ap2002's Avatar
we need more info on your truck, what is the rest of the mods?
Old Aug 3, 2008 | 09:42 PM
Default ~
04 CHEVY TRUCK 408 13.5@103 1/4 225/62 afr head
Duration at 050 inch Lift: 216 int./224 exh.
1.8 rockers
11and3/4 to 1 compression
3.42 gears
Old Aug 3, 2008 | 09:43 PM
dirt track racer 81's Avatar
my cam in sig is a good 408 cam
Old Aug 3, 2008 | 09:46 PM
Default power
what kind of power are you makeing with the cam & where do you shift at (RPM'S)
Old Aug 3, 2008 | 09:50 PM
well considering my trans broke within 3 days of having it goin i have no clue
Old Aug 3, 2008 | 09:55 PM
Default lol
damn it man.. sorry to hear that...... are you running the 4l60e. was it a built tran.. or stock
Old Aug 3, 2008 | 09:58 PM
it was the 60e and it was built. got my 370 goin a few months ago and the 3-4 clutch pack went out, i put the cam and .030 milled ls6 heads on and just drove it around with 1-2 gear once i got it running again and made a quick 1st gear pull and broke im guessin the output shaft as the speedo still works
Old Aug 3, 2008 | 10:01 PM
GMCtrk's Avatar
You've still got 3.42s?
Old Aug 3, 2008 | 10:02 PM
Default stall
do you have a stall?
ya i m not to crazy about the 60e... when i first got my truck running ... i blow it up 3 times... this last time around its held togather for the last 6 mo.
