408 towing build
Old Dec 22, 2011 | 03:44 AM
TA63's Avatar
Default 408 towing build
Im thinking of doing a 408 stroker build geared towards towing in my 2000 2500. It would use TEA ported 317's, a rotating assembly from texas speed, EPS truck torque 2 cam, and long tubes. I think I may also need a larger throttle body, such as the nick williams 92mm unit. Will this tb fit my stock intake? I feel a FAST setup might be overkill, considering this engine will seldom operate above 5500.
Old Dec 22, 2011 | 06:29 AM
SweetS10V8's Avatar
The cool thing about the FAST is that it makes power accross the board, not only at high RPM.
Old Dec 22, 2011 | 07:55 AM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Do you have some sort of alert set up when anything about a FAST intake is posted? It seems like I always see you in them
Old Dec 22, 2011 | 11:59 AM
TA63's Avatar
Believe me, its not that I don't want the FAST intake, its a cash thing.
Old Dec 22, 2011 | 12:02 PM
ltr450ryder's Avatar
Ya I just bought one for my my build not cheap at all lol
Old Dec 22, 2011 | 06:30 PM
SweetS10V8's Avatar
I have done a lot of testing on them, and they are really worth the money.
Ive tested the edelbrocks as well all of the OEM LS car/truck intakes, so i understand intake more than most.
I also had a bad expereince with an engine that was a terrible combination, and it sucked. I try to keep people out of the same situation as I was in. (First engine was 350 SBC, 882 heads, Single plane intake, 750 carb, 8.5:1 compression, 254/264 .525 lift solid flat tappet cam)
Old Dec 22, 2011 | 07:05 PM
TA63's Avatar
Ouch, I bet power was nonexistant below 3500.
Old Dec 24, 2011 | 07:25 PM
1nasty86's Avatar
Turd Gen Guy
should make for a nice combo!
Old Dec 25, 2011 | 09:38 AM
evand's Avatar
Your heading in my direction. I just added a FAST LSXRT I am going through some tuning issues but I can feel power picked up everywhere across the board.
I think a TBSS intake would be a nice addition as well. Much simpler tuning and install. Maybe not as good but gains are gains.
Should be a real nice driver with whatever intake you pick.
Old Dec 25, 2011 | 11:57 AM
charcoal03silvy's Avatar
for towing, i don't see a FAST intake worth the cash IMO. A TBSS or l92 setup would be my option.
Oobray
Jun 13, 2022 03:38 AM
Zizzle
Oct 19, 2017 08:44 PM
2500ZL1
Jan 25, 2016 06:30 AM
chevy6.0fan
Aug 20, 2015 07:10 PM
USMCvet0311
Aug 14, 2015 10:28 PM
