408 Stroker Not Starting-Need Help!
Old 12-01-2007, 11:48 AM
sliderbkt's Avatar
Default 408 Stroker Not Starting-Need Help!
I just installed a 408 and have had trouble getting it to run.
It has a good starter tune, so I don't think that is the problem.
It will start and run rough for about 3 seconds and then stop. After checking the plugs, they are fouled and wet.
After, putting in fresh plugs, and a better tune I was able to get it to run for about 10 seconds. This time I could feel the headers and tell that only 4 cyl are firing. 2358 are the only ones firing.
Is there anything specific that cause this? Or, do I need to start chasing sensors?
Thanks for your help.
Old 12-01-2007, 11:50 AM
blownerator
BlownChevy's Avatar
make sure all of your coils are plugged in, and all of your grounds are hooked up.
Old 12-01-2007, 11:51 AM
9 Second Truck Club
tarinitup's Avatar
Are all the coils plugged in and working?
Old 12-01-2007, 11:56 AM
sliderbkt's Avatar
Coils and grounds are all plugged in. I'll Double check they are firing, but I'll pretty sure they are.
Old 12-01-2007, 12:00 PM
blownerator
BlownChevy's Avatar
if you have 4 plugs on one side that are not firing.....I think you have a set of coils not plugged in.
Old 12-01-2007, 12:01 PM
sliderbkt's Avatar
OK, I've got an ignition tester and noid light slined up for this afternoon.
Would cam or crank sensor cause this?
Old 12-01-2007, 12:02 PM
sliderbkt's Avatar
2,3,5,8 are firing. Not on the same side. That would be nice though
Old 12-01-2007, 12:03 PM
blownerator
BlownChevy's Avatar
opps missed that
Old 12-01-2007, 02:54 PM
sliderbkt's Avatar
Ok , you guys called it. The dead cylinder's coils aren't firing. I'll hit the search and see if I can find the cause.
BROKE-aSS-BLAZER
10-13-2017 03:50 PM
sTNT971
09-26-2015 04:22 PM
11MPG
09-10-2015 08:34 PM
Quick Reply: 408 Stroker Not Starting-Need Help!
