408 compression ratio
Old Oct 22, 2006 | 03:37 PM
Stoichiometric's Avatar
Default 408 compression ratio
I will have everything to assemble my turbo 408 pretty soon and wanted to get some opinions on a static compression ratio. I have -32cc pistons and 74cc heads and end up with ~8.0 to 1 with a .040" head gasket. Should I shoot for a little more compression, or leave that room for extra boost? This engine will run on 91 octane only, I don't plan on any meth or water injection. Any opinions are welcome!
Old Oct 22, 2006 | 03:49 PM
nightrunner's Avatar
Mr. Obvious
how much boost are you planning on runnin?
Old Oct 22, 2006 | 03:53 PM
quicksilverado's Avatar
When I was running 7.8 cr on the 370 it would miss some. Everyone wanted to know what size cam it had un it.
Old Oct 22, 2006 | 04:14 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
8:1CR will SUCK while out of boost. Especially in your heavy truck. If you arent shooting for 20+psi then I would shoot for 9:1 Ill be running 9.3:1 to help out with off boost driving.
Old Oct 22, 2006 | 05:17 PM
EXTREME's Avatar
what would be an ideal cr with a truck as heavy as his. I'm going to be doing the same kind of build (turbo 408) in my HD and am curious about desired CR while not in boost that will still have good power.
Old Oct 22, 2006 | 05:45 PM
1slow01Z71's Avatar
IMO what Im going with, my truck is almost as heavy as ya'lls
Old Oct 22, 2006 | 06:06 PM
Rhino79's Avatar
9 Second Club
Maybe 8.5 or 9.0, and less boost?
Old Oct 22, 2006 | 07:43 PM
I was planning to run about 15+ pounds. I have been told that I can run a lot more, I may want to get to 20psi eventually. I don't plan to race my truck and I don't care what times it will put down (obviously not good because of the weight), I just want tons of street friendly power. I was thinking of a 226/220 .600 on a 115. My heads and pistons are already bought, so all I can do at this point to raise the c.r. is a thinner head gasket. Do you guys think 20psi @ 8:1c.r. would be too much stress on a possible daily driven truck?
Old Oct 22, 2006 | 08:00 PM
8ALTNG's Avatar
No need to run that much boost. With a 8.5:1 comp 408 and a 88mm on it you should be able to make mid to high 6xxrwhp all day long for a long time at like 11lbs of boost. That is the best way to do it. Trust me I know. I drove aroung at 15lbs all the time with my 4.8 set up and would turn it up to 18lbs every once in a while and they dont really like that. :
Old Oct 22, 2006 | 08:06 PM
1slow01Z71's Avatar
It will be a dog out of boost ask turbogibbs about his setup in his MUCH lighter truck. Smallest headgasket you can go with is a .04 an thinner and you will have problems with the pistons dusting the heads.
