408 With 224r cam?
Old Mar 26, 2011 | 07:36 PM
06FASTLQ9's Avatar
Default 408 With 224r cam?
Im putting together 408 with 243 heads i have a new 224r 114 cam i was going to use in the 5.3 would that cam work ok in the 408 or is it to small im running a yank pt3200 3.73 gears.
Old Mar 26, 2011 | 07:41 PM
SLOXCAB's Avatar
It will work but that 408 will perform better with more cam and more converter
Old Mar 26, 2011 | 07:50 PM
06FASTLQ9's Avatar
Would a torquer v2 be ok my buddy has a used one he will trade for my 224r
Old Mar 26, 2011 | 09:07 PM
tarinitup's Avatar
9 Second Truck Club
I used a 228 230 on my first 408 and loved it. Ran 11.50s on nitrous then switched to larger cam and only ran 11.2. Smaller cam had great power off idle and larger cam pulled like crazy up top but lost a bit down low.
Old Mar 27, 2011 | 05:50 AM
06Sierra2's Avatar
i think the v2 cam would be better and you would be fine with your stall and gears.
Old Mar 27, 2011 | 09:14 AM
Beatdown Z's Avatar
Laid Back
Anything done to the 243's?
Old Mar 27, 2011 | 12:56 PM
custm2500's Avatar
Ph.D. in HUBRIS
I would think it is a bit small but you already have it and you won't leave too much on the table. I say run with it. If you decide later you want more then you can swap it for not much time or money.
Old Mar 27, 2011 | 01:04 PM
caddy03pimpin's Avatar
on my 408 i got a 236 a 246 on a 114 but my comp is 11.1 but i got the blower to help in the bottom and the cam to get those r's up
Old Mar 27, 2011 | 03:57 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Its going to be very similar to stock 6.0 cam on stock 6.0 cubes. Since you are using 243's I'm assuming you are not going turbo. If that's so, I'd recommend a bigger cam -- my mid 230's cams are very "small" in a 408.
Picking a cam depends a lot on your goals and wants. Without knowing those, no one can really recommend a cam for you. I wouldn't run a 224 cam in my 408 personally -- even with the turbo.
Old Mar 27, 2011 | 04:06 PM
TARZAN's Avatar
11 Second Club
Trade for the Torquer V2, especially if it's a straight trade
-Will
