402 cam
Old Oct 1, 2006 | 04:45 PM
sroach20's Avatar
Default 402 cam
i was planning on running a regular 6l and bought a comp xer 224/224 .581/.581 114+4. now im going 402 and need to know how it would run on this for now. im going for a stock sounding ride, so i dont want to go huge.
Old Oct 1, 2006 | 05:13 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Then keep that cam. Anything larger then that and oyu will start to get some lope. With that cam it will still try to hit a little lope but will probably go back to idling normal. Also depends on the exhaust you are going to be running. That corsa will be like a megaphone for any sort of lope, a chambered muffler will muffle the lope better but I wouldnt give up my corsa for any other muffler except for the sts turbo Illb einstalling soon
Old Oct 1, 2006 | 05:48 PM
sroach20's Avatar
gonna try the cam, then i will go with pacesetters and a custom magnaflow catted y pipe. there is no way in hell i will drop that corsa either.
Old Oct 1, 2006 | 07:34 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
That cam won't lope a bit in a 402. Mine doesn't even lope
It's a good choice for a stock sounding ride.
Old Oct 1, 2006 | 07:47 PM
mwalls54's Avatar
Need More N2O Mod
its a small cam for a stroker. it depends what you are wanting to get out of the motor. high hp or lots of tq. with the 114+4 lsa it will idle very nice with not much lope at all.
Old Oct 1, 2006 | 09:53 PM
02sierraz71_5.3's Avatar
http://www.exoticperformanceplus.com...Car.php?car=39
check this
the beast makes 405 rwtq at 2000rpms NA
With the right setup I think it will perform very well the lsa could be alot lower but it should work well.
Old Oct 2, 2006 | 09:42 AM
sroach20's Avatar
check this
after reading that im gonna stick with the cam, thanks.
lawhitediamante
Aug 12, 2015 12:14 PM
steves86ta
Jul 28, 2015 10:21 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
jmarkway
Jul 18, 2015 09:23 PM
