400hp LQ4
#22
from reading around the net i thought the lq4's had 300hp stock? how is a cam and tune going to net 100hp? were there other variations of the lq4 power wise? i thought lq4's came in the "HD" trucks and the lq9 that made more hp came in the ss/denali/caddy/tbss?
#23
lq4 aluminum heads: 325hp & 370lbft
#25
Yeah do the math, a stock engine 6.0 with boltons in a single cab with a stall can break 12s, do you think you could go 12s in a 4200 lb truck with less then 400? cam only 6.0s have gone 12.0 at 110ish.. you will need every bit of 450 to 500 to do that. you do not need a cam to make 400 weather corrected hp in a lq4!
#26
Only the Lq4 in the Denali was rated at 325 hp, then in 2005 it went to 335.
the LQ4 with aluminum heads in the HD trucks was rated at 300hp up to 2007.
Difference between an LQ4 and LQ9 is about 5 hp if the same tune is used, due to the slight difference in comp ratio.
peace
Hog
#28
If you wanna see 400hp on a chassis dyno its gonna take more coin. If 400 flywheel is what your after its cake. To many variables out there to just throw numbers. I prefer to measure my success in E.T.'s...
calsdad
Jun 14, 2023 11:07 PM
