4 degrees advanced
Yes.
INCREMENTS!!!
Advancing the cam is a mechanical process, just like advancing a timing on a distributor. Rotating the cam in respect to the crank either advances or retards the cam (depending on which what you rotate). With an adjustible timing chain, you can turn the cam while the timing chain (and crank) is kept static.
INCREMENTS!!!
Originally Posted by Snake Eater
INCRIMENTS
hey dipshit if your gonna clown on someone for spelling make sure you spell it right first.
and i did use spell check but i guess i high lighted the wrong word. besides that i'm from the south so its incerrments lol.
Banned
u say u r not planning on doing this but say u put a motor together and it has to much bottom end and u feel it may be falling off on top the u can keep the same cam and just change the * of the cam to help u out.and i have seen this make big difference n our trucks
here's my unedgmucated question on this. Tuning. In today's world (HPT, EFILive, & such) why couldn't you just advance or retard the area of concern in your spark tables? My cam comes with a 4* advance that I opted not to dial in (custom cam someone didn't want), but I wonder if you "dial it in", then you are stuck with that advance all throughout the powerband, where as in tuning, you can advance and retard where you need. Only to a certain threshold I do understand. Just asking.
Originally Posted by Rhino79
Advancing or retarding the cam is changing when the opening and closing events of the valvetrain happens. When you advance or retard the timing you are changing spark timing.
thank you much. Got it! events are different from spark.
Originally Posted by dewmanshu
thank you much. Got it! events are different from spark.Thread
carid
Oct 1, 2015 09:22 AM
Cammed4ever
Sep 30, 2015 03:38 PM
