4 degrees advanced
Can somebody explain this? How do you "advance" the cam? What's the benefit? Is it done in the grind of the cam, or in the installation of the cam?
It means your cam timing events occur 4 degrees sooner in relation to the crank shaft.Advancing the cam will improve low rev performance,while retarding will improve performance at higher revs at least in theory,in actuality other factors such as head and exhaust flow come into play.Since most of our trucks are driven on the street at lower revs advancing the cam is a better compromise between power and drivability.Advance can be ground into the cam itself or set at the time of installation by means of an adjustable timing set or offset dowels.A degree wheel and dial indicator are needed to check cam timing at the time of installation.
Adjustable chain.
Advancing the cam makes the valve timing events happen sooner, decreases top end hp but increases bottom/mid torque. Did i say that right. My cam lost 9hp but I gained more in the low to mid power band where i use it most. |
so how do you advance it? you said an "adjustable chain"...what's that and how does it set up compared to the stocker?
Just stick with the stock chain and go with the proper LSA
advancing the cam isn't in my plans, I'm just curious how it's done?
It requires a degree wheel and dial indicator. Instructions of how it is done can be found on any cam companies web page pretty much.
lpe sells bushings for your stock gear. they sell for like $2.50 a piece in 1* incerments.
kin wi git spull shecker heer?
