4.8L build to 366 c.i.
Old Apr 25, 2008 | 04:22 PM
  #61
ONLYA4.8L's Avatar
The guys at tsp told me the 383 on a 4.8l couldnt be done.. This is what they said..
"Thanks for your inquiry. You will not be able to use your 4.8L block for this rotating assy. It uses a 3.905" bore, and your block would have to be bored well over .100"! This would not be good for your setup considering that you're looking to run two power-adders. You may consider a 370 cid iron-block short-block for your truck. This will be a very strong setup, and with an upgrade to an ARP 2000 rod bolt and using the Diamond Racing dished piston set it will make for a very strong setup. You can see the forged 370 cid short-blocks on our website at the link below:
It had a link there.. think they are tryin to get me to buy one of their set ups? or they tellin the truth.. And should i go with a 370 set up?
Old Apr 25, 2008 | 04:30 PM
  #62
bluecajun5.3's Avatar
11 Second Truck Club
tsp is full of ****.
you can bore out the 4.8 to 3.905 with a 4" crank so you can have your 383.
Old Apr 25, 2008 | 05:23 PM
  #63
mcfarlnd's Avatar
Un-Registered User
Old Apr 25, 2008 | 05:49 PM
  #64
ONLYA4.8L's Avatar
asholes.. just tryin to get me to buy on of their 370s.. Well ill let u know how the build is going.. i found an assembly for the block.. now some heads.. i was thinkin ported 6.0l heads
Old Apr 28, 2008 | 01:13 PM
  #65
Rick_Vor's Avatar
Does the 4.8l and the 5.3l share the same piston? If your going to boost it big time, you could bore the 4.8l block out to 5.7l bore, but some LS1 forged pistons (stock bore) and run the 4.8l crank and rods (with ARP Rod bolts). I think that would give you a RPM happy shortblock that may still return some decent mileage.
I have thought about building that combo but at 10:1 compression and then boost it 15-16 lbs. It would need a ton of Meth under boost to control detonation but the 10:1 would make it efficient without boost. The 10:1 would keep the torque up without boost. I have read that the Turbo Buick guys build a lot of high Compression shortblock and run crazy boost numbers. It would be cool to have a truck with 500-550 RWHP and still return 18-20 MPG.
Rick
Old Apr 28, 2008 | 02:54 PM
  #66
1FastBrick's Avatar
Custm2500's Rude Friend
Rick
I believe the compression height of the 5.3 and 4.8 piston are different since the crank and rod lengths are different.
Old Jun 12, 2008 | 02:45 PM
  #67
moes04silverado's Avatar
anyone have any updates? I have a 4.8L on my floor that needs something done to it now that my 6.0 is blown to pieces!!!
Old Jun 12, 2008 | 06:00 PM
  #68
Keith's Avatar
The 4.8L piston is a flat top with around a 1.331" compression height.
The 5.3L piston is dished with the same compression height.
Old Jun 28, 2008 | 09:10 PM
  #69
acethedragon's Avatar
compression height the same, weights are different. rod length makes up the difference of the stroke. go ahead and bore it out and stroke it to 383. with moderate boost and juice, the motor will be the least of your worries. have fun with it no matter what you decide
Old Mar 22, 2025 | 07:21 PM
  #70
Go-or-blow's Avatar
Registered User
Default Boat anchor
Originally Posted by r3dh4tch
Why would the block be weaker compared to a 6.0L? In my mind, when I think about the bore centerline on the 6.0L compared to that of the 4.8L/5.3L, I think it has potential to be stronger if left at a relatively stock bore (3.780"). Last time I checked people couldn't bore the 6.0L much without having to worry about having thin cylinder wall thicknesses. I know the 6.0L is tried and true. My brother has one in his truck, and I have wanted to do the same since we did his swap. But since I thought up this build, it looks like it would work just as good as doing a built 6.0L lq4/lq9 (in stock displacement). I'm not looking to build some big cubic inch engine... But for the money, I think it would be worth the effort of trying something different, especially when I know it will work. I don't have any doubts that this engine will be any weaker then a 6.0L... and who knows, it might be something new people start building if it make nice numbers. Worst case scenario, I lose 500-1000 on the block work/pistons, and end up taking the crank/connectings rods and putting them into a lq4 block and buying a new set of pistons and would have a 408. I know these engines are strong, there is a guy running a stock 5.3L at 18psi making over 700 rwhp with a twin turbo setup. The kind of numbers he's making is what I'm looking for, but with a little more reliability from the engine.
Before you anchor that boat to the 4.8l save the crank and rods then anchor the boat all you want! But a 6.2l because them 6.0 belong anchoring the Exxon Valdez! Put the 4.8 crank and rods in the 6.2 cam,port,polish,heavy springs,and what ever power adder you want wether supercharge or turbo and let your right foot do the thinking you'll be all set
