4.8/5.3 pistons?
Old Jul 2, 2006 | 01:43 AM
TurboGibbs's Avatar
Originally Posted by PappyDan
he could use the 5.7 pistons, rods, and crank in the 4.8 and just turn it in to a 5.7 with a set of 4.8/5.3 heads.
The 4.8/5.3 block can be bored to the 3.898(5.7) bore and use 5.7 pistons of course. 5.7,5.3 & 6.0 pistons all share the same wrist pin height in the piston due having the same stroke crank and same length rod. The 4.8/5.3 heads will add compression over using 5.7 heads.
Old Jul 2, 2006 | 10:43 AM
TURBHOE's Avatar
my number 1 &3 have oil on the spark plug threads when i pulled them out. would this be rings or valve seals? this is why i wanted to know. i need a cheap way to get a good motor in my truck if its the rings. although those two pistons did hit a 265-270 on a compression test. all the others hit 195-200.
Old Jul 2, 2006 | 08:02 PM
TurboGibbs's Avatar
The extra oil in the cyl could help the rings seal and give better pressure on a compression test. Most likely it is just valve seals/guides. A second ring busted could show good on a comp test but have blow by and burn oil. If you don't have excessive blow-by, smoking or high oil consumption I wouldn't worry about it. If it isn't fouling the plugs then i'd be in no hurry of replacing the motor.
Old Jul 2, 2006 | 09:35 PM
TURBHOE's Avatar
it does use a little oil but as per gm its "normal" for this one i guess. about a quart or alittle more every oil change. is there a way to check the vave seals?
Old Jul 2, 2006 | 09:52 PM
TurboGibbs's Avatar
If it puffs smoke out the pipes when you first crank it in the morning then that is a sign of leaking valve seals. That is pretty much the only way to tell short of tearing it down.
Old Jul 2, 2006 | 11:59 PM
427's Avatar
427
The 4.8 and 5.3 pistons have the same pin height and should interchange for a cr gain. The shorter stroke is made up in the longer rod.
Kurt
Old Jul 3, 2006 | 12:06 AM
TurboGibbs's Avatar
Kurt
your right, I stand corrected.
Old Jul 3, 2006 | 09:36 AM
TURBHOE's Avatar
thats what i thought but didn't want to argue lol. is there some where to look up the specs and make damn sure of this or is it just in the math that with the longer rod short crank and same deck height that this should work?
Old Jul 3, 2006 | 09:38 AM
TURBHOE's Avatar
i'll check that i think it does. last truck i had was a s-10 with a 4.3l and they were known for that so i never thought to pay any attention to this one.
lukn4trbl355
Oct 21, 2015 11:19 PM
turbo6c3
Oct 5, 2015 06:11 PM
trevorh1
Sep 27, 2015 08:47 PM
sTNT971
Sep 26, 2015 04:22 PM
