4.8/5.3 pistons?
Originally Posted by PappyDan
he could use the 5.7 pistons, rods, and crank in the 4.8 and just turn it in to a 5.7 with a set of 4.8/5.3 heads.
my number 1 &3 have oil on the spark plug threads when i pulled them out. would this be rings or valve seals? this is why i wanted to know. i need a cheap way to get a good motor in my truck if its the rings. although those two pistons did hit a 265-270 on a compression test. all the others hit 195-200.
is there a way to check the vave seals?
Originally Posted by 427
The 4.8 and 5.3 pistons have the same pin height and should interchange for a cr gain. The shorter stroke is made up in the longer rod.
Kurt
Kurt
thats what i thought but didn't want to argue lol. is there some where to look up the specs and make damn sure of this or is it just in the math that with the longer rod short crank and same deck height that this should work?
Originally Posted by mjhoward
If it puffs smoke out the pipes when you first crank it in the morning then that is a sign of leaking valve seals. That is pretty much the only way to tell short of tearing it down.
i'll check that i think it does. last truck i had was a s-10 with a 4.3l and they were known for that so i never thought to pay any attention to this one.
lukn4trbl355
Oct 21, 2015 11:19 PM
