4.00 or 4.005 piston
Old Jun 24, 2011 | 02:45 PM
droppedchev's Avatar
Default 4.00 or 4.005 piston
im throwing in forged rods and pistons didnt know if i should just use a stock bore 4.00 bore piston or use a 4.005 piston and hone the rest any suggestions
Old Jun 24, 2011 | 07:17 PM
Gadgetized's Avatar
If the crosshatch is good, and the cylinders measure good, there would be no reason to hone it. I would stay stock unless there is a problem.
Old Jun 24, 2011 | 07:27 PM
joeyc125's Avatar
11 Second Truck Club
You would have to have a machine shop hone it to 4.005. They should use a torque plate and ridgid hone for it. If your cylinders are in good shape, dingleberry hone it and fit your own rings and stock size pistons and you will be good.
Old Jun 24, 2011 | 07:54 PM
The motor is mint shape it only has like 20,000 miles on the motor only thing that happened is number 7 cracked the pIston that's why I was thinking the 4.0 bore will be good
Old Jun 25, 2011 | 07:50 AM
silver-mod-o's Avatar
Hunt&Fisherator
Use stock size forged pistons IMO. Measure your piston-wall clearance meticulously and adjust it based on what the engine is being built to do.
Old Jun 25, 2011 | 10:00 AM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
What year is your LQ4? I might be interested in the rods if they're the newer style.
Old Jun 25, 2011 | 11:20 AM
There the older style I believe it's a 02 or 03
Old Jun 25, 2011 | 05:06 PM
stock48's Avatar
9 Second Truck Club
No problem running the std factory bore and dingle ball hone it, only problem you will run into is the factory bore is 4.0015-4.002" and factory pistons are 4.000". Most aftermarket pistons assume the bore is 4.000" and will be loose. Im working with Autotec to build me pistons in the 3.9985" for the 4.002" factory bore as we speak. Most 4" forged pistons will measure 3.995-3.997" depending on alloy.
Old Jun 25, 2011 | 07:04 PM
So the Std bore piston will be fine tho just throw a quick hone on it and throw it back together I should get the whole thing balanced right
lukn4trbl355
Oct 21, 2015 11:19 PM
turbo6c3
Oct 5, 2015 06:11 PM
trevorh1
Sep 27, 2015 08:47 PM
sTNT971
Sep 26, 2015 04:22 PM
