395 stroker?
Old Apr 20, 2012 | 06:45 PM
63chevy's Avatar
Default 395 stroker?
I haven't really seen this done very much, but the ones i have been able to get info on haven't made very much power. I have a 5.3 i was considering doing this with but i haven't been able to find much. Any input/suggestions would be awesome!
Old Apr 20, 2012 | 07:29 PM
dmelvin's Avatar
From what I've been reading on strokers, they don't make much more HP than the regular displacement. The idea behind a stroker is a whole lot more torque and a WHOLE lot more torque under the curve.
Old Apr 20, 2012 | 07:38 PM
63chevy's Avatar
Well i realize that. but i meant the numbers i have seen aren't that much better than what my gen1 383 was making. has anyone done this with a 5.3 block? what kind of clearance issues might i run into?
Old Apr 20, 2012 | 07:45 PM
I did this in my transam
I'll post up later more info when I get home
Old Apr 20, 2012 | 09:41 PM
This is the engine setup
LS6 block, Callies compstar crank (4.125 stroke) , Lunati pro billet rods, Lunati forged pistons 3.903, Cleveite bearings, Total Seal rings, Rollmaster double roller w/ Torrington bearing, Ported LS6 oil pump, Comp Cams custom grind 246/252 .615/.625 110LSA, Comp “R” lifters, Comp hardened push rods, ARP head studs, TSP stage 2.5 LS6 heads w/ Platinum dual springs and Titanium retainers, Factory rocker arms, LSX 92mm intake manifold, PTM 92mm Throttle body, Factory fuel rails w/ 38lb injectors, factory coils with new GM wires and NGK TR6 plugs, GM water pump, ASP under drive pulley MTI carbon fiber "look" air lid, SLP bellows.
The car put down 515rwhp and 491rwtq
Old Apr 20, 2012 | 09:47 PM
ltr450ryder's Avatar
What was the cr on this motor?
Old Apr 20, 2012 | 10:25 PM
63chevy's Avatar
Wow thats really good. I bet it made really good torque all along the curve. What did you have to do as far as notching the block to clear the rods?
Old Apr 26, 2012 | 10:56 PM
slowswb's Avatar
Thats crazy talk!!! Thats like saying stock displacement 6.0 is better than a 408.
Old Apr 26, 2012 | 11:16 PM
CC05's Avatar
Just for a bit of future reference, you don't have to bore/stroke/bless these LS motors to get a lot of power from them. Unlike the 'ol famed small blocks, they're a hell of a leap in every way, i.e. virtually stock 4.8's making 650+ hp on higher-moderate boost. If you already know that, then just ignore what I'm saying.
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
sTNT971
Sep 26, 2015 04:22 PM
MOBBN
Sep 22, 2015 08:07 PM
