370/MP122 Build
Old May 17, 2007 | 06:19 AM
  #61
dhpro's Avatar
OK...took some pix and video last nite, cudn't get either to load after an hours work last nite...I'll post by the weekend I hope, but shud also take delivery !!! as well.
A few minor probs I cud use some help with:
1st - engine lite code #P315 - driveshaft relearn...this is the basis key in...yada, yada, right?
2nd - voltmeter reads only 11+ amps charging down from normal 14...shud I be changing my battery or alternator or what?
BTW...sounds great!!!!
Old May 17, 2007 | 08:30 AM
  #62
DrX's Avatar
DrX
P0315 ........ You need to have the "crankshaft position (CKP) variation learn procedure" performed by a dealer or tuner. I know EFILive can do this.
I assume that the alternator is connected. Does the guage show 11V at all RPMs or just at idle? Did you put a voltmeter on the battery when it is running to see if you get the same reading there? Should be like 12V engine off, 14V engine running.
Old May 19, 2007 | 11:48 AM
  #63
dhpro's Avatar
AHHHH! Nelson forgot to program the 4L80 so its stuck in 3rd This stuff really is Murphy's domain!!! Asked Nelson to overnite another tune to get me rollin, but they're impossible to reach!!!
Old May 19, 2007 | 03:35 PM
  #64
91_bowtie's Avatar
I would strongly suggest finding someone local to help you out with the tuning. Your truck will never be at its full potential until you do.
Old May 19, 2007 | 03:50 PM
  #65
FlaBouy's Avatar
If you have HP Tuners, go to the HPT forum and look up EC_Tune...he can hook ya up... He has spliced a couple of the Av 80E tunes over in our truck club....
Good Luck
Old May 20, 2007 | 12:06 PM
  #66
dhpro's Avatar
Agreed...but I already had one of their tunes so it was a good starting point, until I can break it in and get proper tuning. R/
Old May 20, 2007 | 12:07 PM
  #67
dhpro's Avatar
Good Luck
I was actually starting to do some research on buying EFILive or HPTuners so I cud tune it myself - or start to learn! R/
Old May 20, 2007 | 12:10 PM
  #68
dhpro's Avatar
My builder did all the checks and tells me its 12.2v with a meter..battery is fine...prior to the install the guage in the ruck read 14 even, and now its only 11ish...I wondering if its a ground prob...theyr'e gonne test it more and try another alternator and/or battery to see if either is the prob...hopefully an easy fix...cud be that I need the 140amp alternator. R/
Old May 23, 2007 | 02:51 PM
  #69
dhpro's Avatar
Its alive!!!! All good and running driveable...now we gotta fine tune the PCM!
Old May 23, 2007 | 03:15 PM
  #70
ChevyThunder17's Avatar
Congrats! Get to a dyno and get tuned. I think Eastside Performance is in your neck of the woods...
