370 build ideas
Old Jan 19, 2014 | 12:26 AM
shootermwc's Avatar
Default 370 build ideas
Ok, I;ve got an LQ9 block that I'm gonna bore out and get built in the next few weeks/months. here's my plan:
LQ9 bored .030" over (370ci)
Manley forged pistons and H-beam rods
RHS small bore LS7 heads (266cc runner)
Comp dual springs w/ tooled steel retainers
Custom grind cam (TBD)
Chromemoly pushrods
Comp Ultra Pro Magnum rockers
TCI Rattler harmonic balancer
ZEX LS plate nitrous kit (150-200 shot)
42 lb/hr injectors
Parts I already have:
K&N intake kit
American racing headers
Spintech Pro 6000 series muffler
FAST LSXRt 102 intake w/ billet fuel rails
92mm FAST TB
BE COOL aluminum radiator w/ dual E-fans
EGR delete
and several other bits and pieces
thoughts?
Old Jan 19, 2014 | 02:14 AM
Boost-freak's Avatar
this intake have a lot of tuning problems from what i read you can go another route with another intake ,
i hope it all go very well and good luck sir
Old Jan 19, 2014 | 02:17 AM
Mangled03gmc's Avatar
Baltimore Whore
^^^ *** a fast intake. Other then that thats a good build. Go with a pro floe or holley intake
Old Jan 19, 2014 | 04:52 AM
Gadgetized's Avatar
Those heads wont work well. Get the LS3 heads. You would basically be making an LY6 engine. I would also stay away from the fast intake. If I was doing a plate kit I would get a single plane intake.
Old Jan 19, 2014 | 08:49 AM
69Camaro427's Avatar
I agree with the guys on the fast! I have read way to many people having tuning nightmares. A few are having vacuum leak issues but the only idea is a lot of intakes have flexing/warping issues.
If you want strait top end screamer I would go Ls3 or ported Ls3 since you are making the bore 4.030 you should have problems with the valve shrouding.
What CR are you shooting for?
Old Jan 19, 2014 | 12:52 PM
shootermwc's Avatar
I don't see why they won't. They are the new small bore LS7 heads with a 66cc chamber. And I've never had any tuning issues with the FAST intake, which is already installed on the 5.3 that's in it. Had an intake seal leak because I forgot to loctite the intake bolts cuz it was 2 am when I put it on, but other than that, no problems.
Looking at 10.8-11:1 CR. More Pro touring style build than top end drag truck. That will be one day when I can afford to do the rear suspension correctly.
Old Jan 19, 2014 | 02:12 PM
dirt track racer 81's Avatar
I opt for the Vic jr intake and alot better nitrous plate than the zex..
Old Jan 19, 2014 | 02:16 PM
batboy's Avatar
11 Second Club
I don't understand all the hating on the FAST. The GTO guys use them all the time. I have a FAST 90 on my LS1 and love it. If you are experiencing tuning problems with a FAST, you need to find a better tuner.
Old Jan 19, 2014 | 02:22 PM
There's a difference in the fast 90 and the fast lsxrt 102
Old Jan 19, 2014 | 02:26 PM
ltr450ryder's Avatar
266cc runners are huge on a 370.. That I would think would be a topend drag motor if u ask me
