370 build advice or thoughts welcome!
i am going to start building a forged 370 motor just to handle some boost and maybe a little n20. i plan on running the vortech t trim up to about 15-17 psi at the strip if i can make that and about 12-13 on the street . im needing to know what cr should i aim for if im planning on running 91 octane .I still need this to behave well for the street when not under boost. i dont mind running some higher octane for it when i go to the track. im also planning on using a stock 6.0 crank and cnc ported and polished 317's and a 216\222 .547"\.586" 114+3 cam. Id also like to use a little n20 on it like maybe 100 shot just at the track. Im on a budget for this and d like to do it as reliable as possible.im going to use the stock truck intake for now. When i do the n20 im going to use a new intake with direct port but thats later. is there any brand of pistons i should look for in specific? or any other comment or suggestions you may have to help me?
i like how the 10.1 runs now but i know its bit much for the amount of boost i want to run. but the main thing is i want a nicely street driven truck that can run fast at the track too.
is there any affordable forged stock stroke cranks? any of the previous c5 vettes have stock forged cranks?
