350 build up
Old Apr 11, 2009 | 08:54 PM
ryan_wagnon's Avatar
Default 350 build up
Hey im about to start on my engine for my 85 gmc sierra. Im starting off with a 350 block and i mean only the block so this will be a fun build up. Could someone please tell me a good build up of these engines and were they got there parts from. Thanks alot.
Old Apr 11, 2009 | 10:47 PM
budhayes3's Avatar
PT's Slowest Truck
I haven't messed with a small block chevy in a long time so I wouldn't know where to begin, but am I correct in thinking that a 350 block can be stroked to 383? If so, that's the direction I'd be going I'm sure that you can find most of the parts that you need right in the Summit and Jegs catalogs
Old Apr 11, 2009 | 11:43 PM
the powerhouse 383 kit is very affordable, like 500.00 that and some vortec heads and a mild cam and you'll be happy. lots of torque.
Old Apr 12, 2009 | 01:14 PM
L7 Sierra's Avatar
If you wanna keep it very streetable you have the edelbrock performer kit which is very good plus it will pass smog if that a prob for you. Or you can use AFR 185cc heads a comp 260 cam, and a peformer manifold to keep the Q-jet. Have the carb rebuilt by a race shop such as PC carb. Either of those would be one hell of a good driven motor with excellent torque. You could aslo go 383 which would be even better.
But for either 383 or 350 use
9-1 comp piston such as hypertechtonic " I know I butchered it"
roller rockers, summit racings are good for street
keep the Q-jet once set they stay that way, and a Holley will only give you trouble unless you go way big.
Edelbrock performer or Weiland equivalant with a 1 inch spacer is always good.
Add a good windage tray for a few free hp, and better oil control.
If you want a roller cam they add torque but for the cost it may not be worth it unless yoou just want it.
simman22
Jan 21, 2017 10:27 PM
OHsixLS3
Sep 25, 2015 11:20 AM
2500ZL1
Sep 12, 2015 03:50 PM
MA$TER_E
Sep 9, 2015 03:14 PM
iregret
Sep 7, 2015 01:20 PM
