350 bore
Old Jun 8, 2009 | 07:59 PM
ryan_wagnon's Avatar
Default 350 bore
I have a 350 block out of a 89 camaro. How high can you bore these engines can you go over a 400? Thanks
Old Jun 8, 2009 | 08:16 PM
blown 04's Avatar
no a 350 bore is 4.00'' and a stock 400 bore is 4.125'' so you would have to bore it .125 thousanth, not gona happen. throw a stroker crank in that 350 with some 6'' rods, get your cubes thatway
Old Jun 9, 2009 | 10:29 AM
joeyc125's Avatar
11 Second Truck Club
Depends on the blocks, search your casting numbers and you should be able to find out. Some 350 blocks have a bit thicker walls than others. You can go between .040 and .060. Cant go to a 4.125. If you look around 400's are relatively cheap around here anyways if thats what you want to do. But with the siamese bores, you have to make sure your cooling system is up to the task or you will have big troubles fast.
Old Jun 9, 2009 | 07:58 PM
mred's Avatar
.60 is safe but pushing it.
Old Jun 9, 2009 | 08:42 PM
L7 Sierra's Avatar
They have a new 4.OH stroke crank for those little darlings.
Wish they were out when I was playing around with my lunch money.
(^^^*%&^*()*&^$#@$^* house taking all my money
hodge9386
Oct 25, 2015 01:26 PM
lukn4trbl355
Oct 21, 2015 11:19 PM
wickedRCSB
Oct 10, 2015 09:29 PM
gmcyukon
Oct 3, 2015 11:03 PM
Wolftrk99
Oct 2, 2015 08:17 AM
