350 to 383 Stroker question
Old Nov 16, 2010 | 03:24 PM
jeepnfool's Avatar
Default 350 to 383 Stroker question
OK, was originally going to just rebuild my 97 vortec 350, but both heads where cracked so I got new heads, now it looks like I am going to order new pistons also. So my question is to turn it into a 383 stroker, all I have to do is change the crank correct? If so, can someone give me some specs for one? I dont want to spend a crap ton of money on one. I am already into this motor more than I wanted to be, but figured if thats all I have to do and can find one reasonable to me I would go that route.
Thanks
Mike
Old Nov 17, 2010 | 11:04 AM
jeepnfool's Avatar
32 views and no replys? I am trying to seach to make sure this is correct, but I keep getting info on 5.3s, so someones help would be greatly appreciated.
Thanks
Mike
Old Nov 17, 2010 | 01:04 PM
KozzyJr's Avatar
look into eagle strocker kit, they make good products with good prices!!!!
Old Nov 17, 2010 | 02:16 PM
you have to have the block bored .030 over. also have the block massaged so the rods clear the block. speed-o-motive has nice stroker kits also try searching enginekits.com.
Old Nov 17, 2010 | 03:50 PM
Callies Performance's Avatar
FormerVendor
We have Compstar kits starting around or slightly less then $2,000.00
That's the Crankshaft, Bearings (you will need a race bearing) Rods, pistons, rings and locks. Fully balanced ready to rock.
383 = 4.030 bore 3.750 stroke
Old Nov 17, 2010 | 04:13 PM
jeepnfool's Avatar
Nevermind, found the info finally.
ss4chad
Aug 15, 2015 02:25 AM
USMCvet0311
Aug 1, 2015 07:45 AM
Sdailey
Jul 13, 2015 09:17 PM
Sdailey
Jul 11, 2015 08:16 PM
