317s-243s interchangable parts???
Old Aug 25, 2008 | 04:42 PM
bulldogSS's Avatar
Default 317s-243s interchangable parts???
ive got a set of 317s on my silvy SS and want to go to 243s for the compression bump. what parts can i take off of my 317s and put on my 243s??? im guessing a shorter push rod will be needed?? will the valves and rockers interchange??? thanks in advance Mark
Old Aug 25, 2008 | 08:28 PM
454SuperSport's Avatar
if it is an LQ9 your already 10:1 with the 317s
Old Aug 25, 2008 | 09:24 PM
7845's Avatar
Banned
the 243s and 317s use same parts. now a ls6-243 has longer and lighter valves. a
ls2/ls4/5.3/4.8-243 head uses standard valves
if you bought bare heads you can use your 317 valves. your pushrods wont change.
with using 243s your compression on a LQ9 will be 11.1
5.3Caprice
Nov 7, 2015 08:56 PM
Three6GMC
Oct 27, 2015 08:04 PM
Fast86z
Aug 23, 2015 12:35 AM
mrhino
Aug 7, 2015 10:01 AM
