3000 stall converters
hello everyone,I'm needing some help with who is and who is not a good stall manufacturer price and quality all play a factor. was wondering if I could get some help with my decision so if anyone wouldn't mind to throw out some brands and tips on stalls since I'm new to performance building. need stall for a 4l60e on either a 5.3 or 6.0ls with btr stage 3 and msd atomic air force 2702 intake with true duals. thanks in advance everyone oh and a 373 Yukon duragrip posi in a 04 Silverado extended cab
looks like I gotta build this motor first and dyno it to see my hp and torque for the spec chart on circle d converter build. been told its best to got a stall that stalls before highway cruise but after the cam stall point. does that sound correct? some old dude told me this the other day at the shop had a nice 70 short wide 60swapped.
PI,Circle D, Yank. That used to be the case but a converter on a modern vehicle locks up so doesn't matter anymore. I've had 2 PI's they were perfect and so was customer support. Been years ago though. The vendor will help you pick one with a dyno sheet. Have fun!
Call up one of the converter companies listed above and they will be able to answer any questions to get you fixed up. Also remember it usually takes about two weeks to build a converter as they are built vehicle specific... unless you buy an off the shelf converter like B&M which is not recommended.
j4nash
21
Apr 26, 2005 11:44 AM
