243's on 5.3
Old Nov 26, 2007 | 01:15 PM
RandomHero's Avatar
Originally Posted by Truckshop
the ones i got are off of a tbss. they are ls6 heads with 2.00 intake valves.
So then they'd be ls2 heads not ls6 heads
tdrumm's Avatar
Originally Posted by Onetogofast
Cool, hope it runs good. What size are the intake valves on a stock 5.3 head? Thanks for the info.
Stock 5.3 have 1.89 intake and 1.55 exhaust
Old Nov 26, 2007 | 03:34 PM
Truckshop's Avatar
yep! same casting #'s but no sodium filled valves
Old Nov 26, 2007 | 03:49 PM
joshua022's Avatar
Did you have to get custom made pushrods since you had them milled??
Old Nov 26, 2007 | 05:23 PM
Truckshop's Avatar
nope. between the milling and the smaller base circle of the tr220 i used 7.400 pushrods.
Old Nov 26, 2007 | 06:10 PM
joshua022's Avatar
once you get it tuned in are you going to go to the dyno??
Old Nov 26, 2007 | 06:20 PM
JHALL7644's Avatar
are these stock push rods ur using
Old Nov 26, 2007 | 06:22 PM
marksboy7's Avatar
Same setup that I am planning on running with my truck. Interested to see how you like it.
Old Nov 26, 2007 | 06:24 PM
joshua022's Avatar
7.400 is the stock length
I don't know but i'm kinda thinkin' they are hardened pushrods since he has a cam. That is usually the way you go when you go with a cam.
Old Nov 26, 2007 | 06:26 PM
JHALL7644's Avatar
Originally Posted by joshua022
7.440 is the stock length
ok cool, what i wanted to know
