243 milled 35 on ls1 what size rod will i need?
Old 09-18-2009, 02:24 PM
Registered User
SILVANO 21's Avatar
Default 243 milled 35 on ls1 what size rod will i need?
i have a stock ls1 with a tsp 228r cam and want 2 mill the heads down 35 2 get from 64 cc 2 59cc will i be able 2 use the stock 7.4 rods? or what size will i need
Old 09-18-2009, 03:14 PM
00_Hotrod's Avatar
The stock 5.7 rods should measure somthing like 6.096 center to center, U shouldn't have to change rods, just check the VTP..
Old 09-18-2009, 06:51 PM
NoShow's Avatar
I think he's talking about pushrods. If you plane the heads .035 you may need different pushrods. Are you sure you can take .035 off those? What about PTV?? What C/R are you shooting for, like 11:1?
I'd have your local speed shop measure and install some hardened ones and set up your springs for ya
Old 09-18-2009, 09:08 PM
PT's Slowest Truck
budhayes3's Avatar
A pushrod length checker is less than $20, and well worth it when milling heads and such. Taking .035 off of the heads will require a shorter pushrod or the lifter preload will be too tight, especially if you're using new replacement LS7 lifters, which have a taller cup.
Old 09-19-2009, 12:01 AM
Registered User
SILVANO 21's Avatar
yeah 11.1 thats what am looking for yeah i went 2 the machine shop and they said i could they said if i deck them 35 it will bring me from 64cc 2 59cc
Old 09-19-2009, 12:03 AM
Registered User
SILVANO 21's Avatar
and the PTV am not sure i did a little measuring and i dont think they will hit if i deck them 35
Old 09-19-2009, 02:04 AM
Fastcount03's Avatar
Use tootsie rolls!!! lol Assemble your decked heads on the motor with a microwaved tootsie roll on the number one cylinder, rotate the motor, remove the heads then the tootsie roll, freeze the tootsie roll, then mic it to see PTV clearance. That simple!!
Old 09-19-2009, 03:14 AM
8 Second Truck Club
Blown06's Avatar
you forgot a step...
...when done measuring frozen tootsie roll, let thaw for 11.3 minutes, then eat tootsie roll.
Old 09-20-2009, 08:54 AM
Truckshop's Avatar
7.4 pushrods will work fine if using a aftermarket cam. i milled 243's .040 with a tr220 and used 7.4 pushrods on a 5.3. the only correct way is to measure.
Old 09-20-2009, 10:24 AM
dirt track racer 81's Avatar
a little simple half *** method i used was just when i milled mine .030 and used a .040 head gasket. i took took 7.4 - .030 and then took whatever stock head gasket is - .040 and iirc i have a 7.35 rod
Quick Reply: 243 milled 35 on ls1 what size rod will i need?
