224 in a 4.8
Old May 25, 2009 | 12:41 AM
02_Orange_D1SC's Avatar
Fastest D1 Procharged Truck
Default 224 in a 4.8
well i can get my hands on a tr224/563 on a 112lsa for a good price off one of my buddys but my problem is i have a 4.8 im thinking its to big i would like to go with a 220/581 on a 112lsa i allready have a ss3600 verter and 4.10s fully built trans LTs supporting mods but is it worth it i dont like doing things twice
Old May 25, 2009 | 01:09 AM
skeet's Avatar
try it you might like it !!! you got the supporting mods, specially if its cheap enough, do you have p&p heads
Old May 25, 2009 | 01:14 AM
no i dont have any head work done yet but i plan on doing a set of either TEA 2.5 5.3s milled to 59cc or a set of AFR 205s milled to 59cc
Old May 25, 2009 | 08:58 AM
litreddevil's Avatar
Banned
uuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuu uuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuu
Old May 25, 2009 | 10:05 AM
Originally Posted by litreddevil
way to big but alot of people here think big is better i have a friend with an ex-cab running 13.26 with a 4.8 with a little 216/220.just remember if the dur. and lift is the same you are leaving some where around 15 to 20 hp and the same in tq.
whats the lift on this cam you speak of sounds like a trick flow i saw in summit racing
Old May 25, 2009 | 10:17 AM
bluecajun5.3's Avatar
11 Second Truck Club
it's not trick flow. it's one of Pete's cams.
i mean Randy does know his **** but 15-20 hp & tq seems a lil on the high side to me.
that's coming from someone who has a tr220...
i really would like to try one of his cams but my junk runs way too good like it is to change something out.
Old May 25, 2009 | 10:28 AM
so you guys think its to big cause if so im not going to waste my time i want to do this one time you think a 220/581 is a better choice or maybe a 216/220 560/560 114lsa
Grumpy5.3's Avatar
with your convertor and gear, you will be ok.... smaller cam would work alot better, cuz the 4.8 does lack bottom end tq. Mine put down 305 I think, It pulled much better up top obviously
Old May 25, 2009 | 08:30 PM
eallanboggs's Avatar
I installed a 224 in a 4.8 nearly 2 years ago that had come out of a 6.0. I also put in some 1.8 Scorpions. Installed Comp 918s and had the PCM reflashed by TSP. It has 25% underdrive and electric fans. All the top end stuff except long tubes and CNCed heads. With the Scorpions the lift is close to 580. It still runs like a scalded dog and I haven't had to ever turn a wrench on it since it left my driveway. Go for it.
AdaMax
May 16, 2016 11:35 PM
legerwn
56
Nov 15, 2015 10:21 PM
97_ek
Sep 23, 2015 09:16 PM
vipergtrdj
Sep 11, 2015 05:52 PM
hackrst
Sep 2, 2015 05:27 PM
