2011 Tahoe AFM delete cam
Old Jan 1, 2020 | 04:01 PM
gregs323's Avatar
Default 2011 Tahoe AFM delete cam
Guys,
I want to delete the AFM and swap a new cam into the wife's 2011 tahoe once the tax return comes this year. I want a cam that will give me the same or better fuel mileage with lots of torque. I have a Comp 206/212 in my truck and that swap gave me +2 MPG, I would like to find something similar for this newer engine and retain the VVT capabilities. This will be the first time I mess with one of the newer engines. What do I need for the conversion? It sounds like I would need headgaskets and LS7 lifters and ?pushrods? Anything else? Can I run LS9 valvesprings?
Thanks,
Greg
Old Jan 1, 2020 | 04:43 PM
madmann26's Avatar
BTR makes a kit for this.
I would buy the kit rather than piece mill it.
Old Jun 14, 2020 | 10:23 AM
gregs323's Avatar
After searching through the BTR website I decided against it because they didn't have cam specs listed on their website and a lot of stuff was out of stock,that's a red flag to me. I've sourced all the parts I need for the AFM delete except for cam/springs/pushrods. Does anyone have recommendations for a mild VVT cam to retain fuel mileage?
Old Jun 14, 2020 | 12:23 PM
01FormulaTA's Avatar
If you dont want to lose any fuel mileage the factory L9H cam is prob your best bet. The specs are 198/209 .500/.500 115 LSA. Part number 12623065. These are very similar specs to the 2000 LS1 cam in the corvettes, alot of truck guys went to this cam back in the day for a small bump in power.
Old Jun 15, 2020 | 02:47 PM
gregs323's Avatar
Thanks! I looked that part number up, looks like I should just use the LS6 springs to be safe. Do most guys just run the stock pushrods? Since it's a factory cam is the VVT limiter needed?
Old Jun 15, 2020 | 03:52 PM
68Formula's Avatar
TSP has a package that has a VVT-compatible camshaft. https://www.texas-speed.com/p-5332-t...t-package.aspx
The nice thing is they include a phaser cal table which should save on complexity trying to tune, and they are the only ones I'm aware of that do this. I don't think too many tuners have experience in optimizing that portion of the cal
As for mileage improvement potential, you'll have to inquire with them.
Old Jun 15, 2020 | 06:04 PM
gregs323's Avatar
Can't find the 12623065 anywhere. Everyone's out of stock. Is this due to Covid or something? One person I talked to mentioned a UAW strike but I'm not seeing anything in the news about a strike.
Old Jun 15, 2020 | 06:47 PM
https://sdparts.com/i-19902861-genuine-gm-parts-12623065-camshaft-6-0-6-2l-single-bolt-non-afm.html
Call Scoggins Dickey, they may have it in stock. LS6 springs would be a good idea, stock pushrods should be fine. Its a factory VVT cam so all you need to do is pull your AFM cam and install this one, everything gets re-used except the AFM Lifters and the AFM Valley Cover.
Old Jun 16, 2020 | 04:53 PM
gregs323's Avatar
Yeah I called them yesterday and they were out of stock. Just got one ordered today from a GM dealer who had one in stock. Apparently the 12623065 cam number has been superseded. The dealers have the new GM number but it shows no availability. That was the best explanation I got about why these are so hard to find.
Thanks, for the help going to go order some LS6 springs now
Old Jun 20, 2020 | 04:06 PM
gregs323's Avatar
Will I need to use a VVT limiter since this is still a stockish cam?
