2010 6.0 LS Relucter wheel
Old Mar 27, 2014 | 06:05 PM
70swb's Avatar
Registered User
Default 2010 6.0 LS Relucter wheel
I have a 2010 6.0 Ls. I'm going to make it carburetored. My question is that it was originally a 58 thooth. It needs a crank. I found one but its 24 tooth. How hard is it to change. Or could I keep it 24 tooth and just order a mad 6ls box for a 24 tooth and change the crank sensor to a 24 tooth
Old Mar 27, 2014 | 10:44 PM
Bill Reid's Avatar
Did you receive the harness and ECM for this 2010 motor? Assuming the cranks are otherwise identical you could have the reluctor wheel swapped... keeping the 58x. Any reputable machinist who has experience with GENIII/IV engines should have the alignment tool and know-how to perform the swap. That would be the easiest IMO...
Old Mar 28, 2014 | 08:05 AM
70swb's Avatar
Registered User
No. No computer no nothing. Just a long block
Old Mar 28, 2014 | 09:01 AM
Bill Reid's Avatar
What engine management controller are you going to use? Its been awhile since I've been in the market or followed controllers but last I knew if you had a motor with a 58x reluctor wheel then you have to stick with it unless you change out the cam/cam sprocket and all the sensors... expensive. This is why I believe it would be cheaper for you just to swap the crank and reluctor wheel... this assuming there is no other damage(?) to the motor you have.
Old Mar 28, 2014 | 09:11 AM
70swb's Avatar
Registered User
I'm going to use the MSD setup. Was hoping I could just change the crank sensor to a 24 tooth
Old Mar 28, 2014 | 10:31 AM
slow67's Avatar
Gingervitis Addict
MSD makes 2 diff LS boxes. One for for 24x and one for 58x.
Old Mar 28, 2014 | 11:56 AM
70swb's Avatar
Registered User
Yeah I know that
Old Mar 28, 2014 | 12:06 PM
70swb's Avatar
Registered User
Just really wanting to know if I can change that crank sensor to a 24
Old Mar 28, 2014 | 12:38 PM
Bill Reid's Avatar
I have never heard of a controller that can accept a 24x reluctor wheel on an otherwise unchanged 2010 motor. Maybe there is a controller out there now that has that flexibility but I wouldn't know who makes it.
Cam position sensing changed when GM changed from a 24x to a 58x reluctor wheel. Also, GM has since added displacement on demand and cam phasing... more to deal with if retrofitting the motor to 24x. I seem to remember engine management (sensors) voltage was changed from 12VDC to 5VDC as well. So, its possible you also need to change these sensors.
I could be wrong but I don't think its as easy as swapping in a 24x based crank...
Here's an old pic I have to show you what the cam sprockets look like when GM first went to 58X. The left sprocket is an early LS2 - 24x reluctor based motor. The right sprocket is an early LS7 - 58x reluctor based motor. The patterning on the front of the sprocket is what the cam sensor picks up. As you can see the 2 sprockets are different...
Hopes this helps...
Old Mar 28, 2014 | 08:24 PM
1Bear's Avatar
I would say you should be able accomplish it by using a 24-tooth reluctor wheel crank and the camshaft gear and sensor for a 2005 LS2, which is a Gen. IV that still had the 24X set-up from the factory. I can’t recall all the vehicles that used this configuration, but the parts are easily available. I would say use whichever style system you had or intended to run, but beings you don’t have anything but the engine itself, you should be able to go either way easy enough.
OHsixLS3
Dec 27, 2016 09:30 AM
JordanH
Aug 8, 2015 07:59 PM
abey15
Jul 13, 2015 02:20 PM
Moto733
Jul 12, 2015 10:25 PM
