2005 5.3 with 243 heads ? what do u think
Old May 2, 2011 | 12:35 PM
05gmcsierra's Avatar
Flat top pistons came in the l33 engines which was on the. 05 Ecsb z71 and in all the nnbs 5.3s..
Old May 2, 2011 | 12:42 PM
dmelvin's Avatar
Originally Posted by hyespeeder
I am getting the heads milled today ... how much should i go ... 0.20-0.30?
.030 with a .40 thickness gasket will put you at 9.9:1
.030 with a stock .051 gasket would put you back to roughly 9.5:1
this is for dished pistons.
dmelvin's Avatar
What heads came on the L33?
Old May 2, 2011 | 12:45 PM
799s... that's what my 5.3 has...
Old May 2, 2011 | 12:49 PM
dmelvin's Avatar
Ok, you can treat them like the NNBS 5.3's then.
OP : if you have the L33... you don't need to mill your heads at all.
Old May 2, 2011 | 01:24 PM
budhayes3's Avatar
PT's Slowest Truck
Originally Posted by bennettracing
Billy the aluminum 5.3 that I got my 243 heads off of had FT pistons I just don't know what year it was !!
Yea, the aluminum 5.3 HO's had flat tops, and were available in 05. That's the engine that Bill (trever1t) has in his hot rod. Not sure what other years that they offered that engine, but I know that it was a short run
Old May 2, 2011 | 01:25 PM
48548's Avatar
Originally Posted by Pollo432
Sorry to butt in but I have a 05 5.3 also. Jw what would be a few signs to tell if u have the aluminum block??
The block would look like aluminum and not rusted metal.... Bright colored bare metal.
Old May 2, 2011 | 01:26 PM
budhayes3's Avatar
PT's Slowest Truck
The block will be aluminum colored and the pistons will be flat tops. Check the RPO sticker in your glove box for L33, if you see that, you have the aluminum block, if you find LM7, you have the iron block with dished pistons like most of us, myself included
Old May 2, 2011 | 01:37 PM
48548's Avatar
Here is a picture of my 05 L33... Also you could try to see a magnet would stick to the block as it shouldn't stick to aluminum.
Old May 2, 2011 | 02:17 PM
Or just check the casting on ur heads... l33 only came on. 05 ecsb z71 package 5.3.. called the 5.3 HO.. has casting 799 on the heads.. anything else means u have iron block
