2.02 ls1 heads on a 5.3
Old Nov 19, 2015 | 07:48 AM
James Workman's Avatar
Default 2.02 ls1 heads on a 5.3
Does anybody know if there would be a fitment issue of ls1 head with 2.02 and 1.6 valves that has been milled down to 62cc thanks for your time
Old Nov 19, 2015 | 07:54 AM
mikeyjm1's Avatar
I'm curious too.
Old Nov 20, 2015 | 01:34 AM
1FastBrick's Avatar
Custm2500's Rude Friend
I am pretty sure they fit just not sure on PTV clearance.
The newer 5.3's had a 799/243 casting and people mill those down all the time.
They also have a 2.00/1.55 valve combo from the factory.
Old Nov 20, 2015 | 06:59 AM
gagliano7's Avatar
I don't if this helps you but i have the prc 2.5 5.3 heads 58cc on a Lm7 with a cam motion 222/226 115+3 .600 lift. The valves are 2.02"/1.575" Stainless Steel Valves.
Old Nov 20, 2015 | 09:19 AM
Thanks I would think they should then, how do you like your set up? Anything you would of done differently
NHolds
Nov 19, 2015 12:04 AM
Inmydust08
Nov 17, 2015 11:03 AM
zblee
Nov 3, 2015 02:37 PM
