1.85 rocker arm??
Old Dec 14, 2007 | 08:42 PM
fastgmc53's Avatar
14 Second Truck Club
Default 1.85 rocker arm??
Anybody know of of any gm vehicle that has 1.85 rocker arms I can use on my LM7 motor? And is the swap to the LQ heads worth it or is it just a small gain??
Old Dec 14, 2007 | 08:59 PM
joshua022's Avatar
I'm pretty sure the 1.85 roller rockers are only an aftermarket part. I don't think they come on anything factory.(I could be wrong)
Swapping the LQ heads to your 5.3 would be a bad idea unless they were milled a lot. Because they have a larger combustion chamber than your 5.3 heads and that means your compression ratio would go way down.
Old Dec 14, 2007 | 09:03 PM
eallanboggs's Avatar
1.7s are stock ratio. You can get the OEM style in 1.85(SLP) or Comp Pro Mags. I believe the Z06 LS7 uses a 1.8 stock rocker.
Old Dec 14, 2007 | 09:09 PM
fastgmc53's Avatar
I see now.... the first article I read said they both have a 71cc chamber but it must be a misprint I just read Car Crafts article showing the LM7 with 61 cc chambers. There isn't any heads with smaller chambers to use either. Maybe somebody knows something on the rocker arms. If not do the LS cams fit in these motors? I know they have very agressive specs.
Old Dec 14, 2007 | 09:19 PM
joshua022's Avatar
yes the LS camshafts DO fit in those motors. You could have your heads milled or buy some with smaller chambers to up your compression ratio.
Old Sep 15, 2009 | 10:16 PM
Matt G6007's Avatar
the ls7 comes with 1.8 rocker arms stock but the intake rocke arms are on a offset so you wouldnt be able to use them but you can try to buy a set of exuast rocker arms from GM and that should do it...
Old Sep 16, 2009 | 11:33 AM
budhayes3's Avatar
PT's Slowest Truck
I remember there being some interest in the LS7 1.8 rockers a few years ago and somebody bought one and tried it out. I can't remember why, but for some reason it didn't work.
Old Sep 16, 2009 | 03:46 PM
Mangled03gmc's Avatar
Baltimore Whore
You will net benny from 317's on our 5.3.. try to find some worked 5.3 heads or ls6 heads and have them done... I would pass on 1.8 rockers..
KINGCYCLES
Oct 2, 2015 10:21 AM
redbird555
Sep 30, 2015 09:28 AM
tim wellington
Sep 29, 2015 10:17 PM
vipergtrdj
Sep 16, 2015 07:06 PM
chvy=power
Sep 8, 2015 11:06 AM
