09 5.3 dod delete
Old May 24, 2017 | 10:37 AM
bustedknuckles8's Avatar
Registered User
Default 09 5.3 dod delete
when doing the dod delete, what to do with the dod plug, does it need to be plugged in to run on 8, or will it run on 4 until the pcm is flashed? new cam, correct lifters etc. thanks.
Old May 24, 2017 | 12:57 PM
Choda's Avatar
leave the plug unhooked.
the tune will shut off the 4 cyl mode
replace the lifters with new ls7
replace the valley cover with a non-dod one. like an ls3 style
Texas speed has kits for what you need.
Old May 25, 2017 | 02:53 AM
Auburn247's Avatar
4.8 valley cover will work also and is cheap
